flogged '66 Electric XII restoration project!
- will
I bought this '66 XII on OSG a few months ago - I've been wanting to try one out for a super long time, but it was difficult to find one that wasn't totally modified or totally expensive. I really liked this one - it has a pretty amazing worn-out "faux-burst" finish.
Here's some "before" shots:
This one needed to have a neck plate & original tuners tracked down, the headstock plugged and redrilled (it was drilled for modern "F" tuners,) and a repair for a nasty crack in the body.
It took a whole mess of ratchet straps to pull closed the crack in the body. I used a glue syringe to try and force glue into the crack. Luckily it held after the glue dried!
It looked quite a bit better with the crack glued closed, but I still needed to patch the big chip of wood that had gone missing. I clamped the body into the mill and machined away the broken stuff to make way for a tiny rectangular patch. The chunk of alder needed to be cut at a diagonal for the grain to match the grain in the body.
...and another ratchet clamp for the patch.
It looked pretty nice after the patch was trimmed and sanded to match the shape of the body. I painted the patch with some black lacquer, and after that dries for a couple weeks I'll level the lacquer and buff it to match the rest of the paint.
I needed some plugs to patch the headstock but I couldn't find a plug cutter that was the right size, so I turned a bunch of plugs on the lathe by screwing some pieces of wood to a scrap of plastic.
Plugs that fit!
All plugged up:
I shaved the plugs flush with the headstock and then redrilled the holes on the mill:
Also, the pickguard was pretty warped, so I flattened it out in the oven:
It's together and working pretty well - I can see how it got so worn-looking in the first place!
Plugs that fit!
All plugged up:
- andy
Re: flogged '66 Electric XII restoration project!
Subscribed! I can't wait to see more of this. There's something special about those xii's.
Send me western swing vids
- Ursa Minor
Count me in too! Can't wait to see more progress!
- Sonichris
Cool! I've been waiting for this one!
- mcjt
May the deities bless you for restoring this needy XII.
- RolandJC120
This looks awesome
- hornz
Only just seen this thread... awesome work, looking forward to seeing the final result. XII's
hornz
Spin The Black Circle
- hornz
Forgot to say, that pick guard outline is incredible! Mine is also an SB '66, does yours have a SPECIAL stamp?
hornz
- will
no "Special" stamp on this one it's just a boring regular XII.hornz wrote:Forgot to say, that pick guard outline is incredible! Mine is also an SB '66, does yours have a SPECIAL stamp?
I finished patching the damage and got it all back together. To touch up the crack repair I picked up some black lacquer - I could only find it in a spray can, so I sprayed it into an old glue bottle (the kind with a brush built into the cap), since I wanted to just apply the paint where it was needed, and not worry about masking. I applied the paint in several coats and waited about two weeks to block sand the touchup flat and buff it out - I'm happy with how the repair blends into the existing finish - the new lacquer really melted into the old lacquer around the borders of the repair!
I've never owned a 12-string before, but this has been lots of fun to play - no wonder it's had so much wear to the finish!
- antisymmetric
Cool skills & techniques, thanks for posting!
- thecolorwaves
Absolutely beautiful guitar, and a super-interesting post. Thank you!
- Bothand Nether
Beautiful!
Precision work on those repairs, Sir.
"No short-haired, yellow-bellied Son of tricky dicky's Gonna mother hubbard soft soap me"
-The late Mr. L.
-The late Mr. L.
- itstooloudMike
Very nicely done! Great looking guitar.
- countertext
When I first opened this post last month, I thought, "That looks incredible - don't touch it!", until that last pic of the huge crack scrolled past. Looks like you did some masterful patching, though, and it still looks beautiful in its loved-in state. Keep making the world a better place!
- hornz
Great work, another old XII saved
hornz
