62 Bass VI...Finally!
i love sharin foo
Re: 62 Bass VI...my oh my... [Update}
Post by i love sharin foo » Thu Dec 27, 2007 5:24 pm
I have one of the CS models. The tuners are the same that they use on the normal guitar scales. The profile of the shaft nor the slot is any different. The tapered wrap on the Fender strings that came stock fit in there with no problems.
Justin
Goddamn this is real
OffYourFace
Post by OffYourFace » Thu Dec 27, 2007 5:48 pm
I think all the new Bass VI's, CS & Japanese, use normal Kluson type tuners.  My Japanese Bass VI had standard tuners as well.
I say just keep looking on ebay.  Most likely someone will have a set and list them as $trat tuners.
sookwinder
Post by sookwinder » Thu Dec 27, 2007 8:26 pm
OffYourFace wrote: I think all the new Bass VI's, CS & Japanese, use normal Kluson type tuners.  My Japanese Bass VI had standard tuners as well.
i love sharin foo wrote: I have one of the CS models. The tuners are the same that they use on the normal guitar scales. The profile of the shaft nor the slot is any different. The tapered wrap on the Fender strings that came stock fit in there with no problems.
Justin
yeah that is what I suspected.  If Fender isn't going to tool up for the correct size bridge for the CS Bass VI then they sure aren't going to tool up for the larger slotted tuners.
DB
Post by DB » Thu Dec 27, 2007 10:43 pm
My CS 2006 looks like normal tuners, but  with the Fender Stainless Steel Strings fit is no problem.  Suprisingly, the tuners on my '95 Reissue definitely have a wider spread.  I don't know if they're as wide as vintage tuners, but they are clearly wider than the ones on the CS.
DB
IV, V, VI, XII...
sookwinder
Post by sookwinder » Fri Dec 28, 2007 5:55 am
here is a pic of a 94 MIJ Bass VI headstock  (up on ebay as I write this)  ...  as DB pointed out the tuner slots do look larger and the profile seems thicker than standard guitar posts.  When were Japanese bass VIs available ?  were there two types of tuners used on the Japanese reissues ... early and late versions ?
eggwheat
Post by eggwheat » Fri Dec 28, 2007 8:12 am
Hi..while I agree fender US probably wouldn't tool up for the correct hardware..The japanese have a totally different ethic...they are the kings of copying..as far as I was aware and as shown in the pictures the Japanese Fender VI has the correct enlarged tuners and correct sized bridge unlike the CS VI..I was sure the twoJap VI's I've owned had the correct VI only parts the only thing wrong was that they didnt make the mute.
The pic above certainly confirms they did the tuners properly..that means fender Japan have a draw full of the correct tuners somewhere!
Can someone now put up some pics of the CS VI tuners?
scottme
Post by scottme » Fri Dec 28, 2007 4:48 pm
OK...
eggwheat
Post by eggwheat » Fri Dec 28, 2007 5:52 pm
Well from this angle they look like proper VI tuners not standard klusons to me!...need a proper close up profile shot to be 100% tho
OffYourFace
Post by OffYourFace » Fri Dec 28, 2007 6:30 pm
The japanese tuners don't have deep 'cuts' like the original ones so i just figured they were the same/usual guitar type.
For the record, My Japanese Bass VI was from '94.  I bought it right when it came out for $599 (!!!)
sookwinder
Post by sookwinder » Fri Dec 28, 2007 6:35 pm
mmmmm  very interesting  .....  two possible scenarios seem to be emerging  ...
1.  Fender japan did tool up and make bass VI specific tuners, although not exactly the same as the originals ,  and have a draw full of them still
2. Fender japan did tool up and make bass VI specific tuners, but not enough and maybe fitted gtr type klusons on some later models
bulrich
Re: 62 Bass VI...[Finally New Headstock]
Post by bulrich » Mon Jul 21, 2008 9:50 am
A few of you may recall the 62 VI I rescued off of Ebay late last fall.
After a few go arounds (and a noble attempt by Stereoordinary) at repairing the massively altered headstock, I send the neck off to Mike Forrester.
Well after some time the neck headstock is finally coming together.
Here's some pictures of his progress:
http://s141.photobucket.com/albums/r56/ ... 008149.jpg
Next will be refret and then the refinish on the body, and neck in Inca Silver.
http://www.notifbutwhen.com/2/Offset-Basement.JPG
theworkoffire
Re: 62 Bass VI...[Finally a new Headstock)
Post by theworkoffire » Mon Jul 21, 2008 10:42 am
Wow - looks like some pretty serious surgery. What a relief to see it coming back into some kind of usable shape.  :)
tsalwel
Post by tsalwel » Mon Jul 21, 2008 10:57 am
holy cow..................
i LOVE this guys work
its INCREADIBLE
he did that to a strat also
fucking great ........!
what a craftmanship
        d
music ALLways
music  IS my motor
Post by Stereordinary » Mon Jul 21, 2008 12:30 pm
Sweet!  Nice to see that coming along so well.  :)
eupat
Post by eupat » Mon Jul 21, 2008 1:33 pm
theworkoffire wrote: Wow - looks like some pretty serious surgery. What a relief to see it coming back into some kind of usable shape.  :)
+1
amazing work on this headstock
will you paint it to match the body, or keep it "natural" ?
the surgery will be quite un-notice-able !
