Wesminster Mustang Competition MIJ 1978 : headstock OK
Jaws of Joey
Re: Wesminster Mustang Competition MIJ 1978:matching headsto
Post by Jaws of Joey » Mon Oct 26, 2015 5:41 am
Any updates on the guitar? Curious about the headstock specifically, as one of my projects is going to have a matching headstock and custom decal.
tubart
Post by tubart » Fri Mar 04, 2016 3:52 am
Jaws of Joey wrote:Any updates on the guitar? Curious about the headstock specifically, as one of my projects is going to have a matching headstock and custom decal.
Finally I won't paint the headstock. I've ordered a Westminster Replica logo that is now in right place and varnish. I'll take some photos soon ;)
tubart
Post by tubart » Tue Mar 08, 2016 12:56 pm
Here it is. The waterslide logo has found its place on the headstock. Several layers of brilliant clear varnish protect it.
Far better than what i was when I've bought it !
Next step : nut slot...
jagstang
Re: Wesminster Mustang Competition MIJ 1978 : headstock OK
Post by jagstang » Thu Dec 08, 2016 3:05 pm
Nice. Have you finished it yet? I have a similar problem with an old mustang body. Original competition car refinished with fiesta red. How have you removed the green finish? Did you made it all with hands or did you use some machines? I'm really new in restoring and don't know, how to start...
Do i have any chance to get the refinish off with something like sandblasting or glassblasting?
mgeek
Post by mgeek » Fri Dec 09, 2016 3:53 am
jagstang wrote: Do i have any chance to get the refinish off with something like sandblasting or glassblasting?
JESUS NOOOOOOOO!!!!!
Removing an overspray can be done very very effectively, especially when over a relatively tough late sixties/early seventies poly finish, but you've got to be gentle.
Get like, 1000 or maybe 1500 grit wet and dry paper, soak it so it's good and wet, then use a sanding block to make sure it's all flat and patiently sand it back.
There are other things to try if that doesn't seem to be touching it, but that's my starting point. I've done this quite a few times now, and very often the overspray isn't even that well adhered to the original paint and with a little work it basically flakes off. If you've only gone at it with high grade paper, all that needs to happen with the original finish is a spot off buffing compound and it's all done
Sandblasting = a place in this thread viewtopic.php?f=41&t=90134
jagstang
Post by jagstang » Fri Dec 09, 2016 7:59 am
;D How i said - i'm new in restoring guitars... I will give the paper a chance and look, if i can do that.
mgeek
Post by mgeek » Sat Dec 10, 2016 2:57 am
Why not start a thread about it? Looks like a cool project...Just make sure you do enough research and be gentle and cautious.
jagstang
Post by jagstang » Mon Dec 12, 2016 12:29 am
Yes, i also thought about it...
cooterfinger
Post by cooterfinger » Fri Dec 16, 2016 6:59 am
tubart wrote:Here it is. The waterslide logo has found its place on the headstock. Several layers of brilliant clear varnish protect it.
Is it finished? An amazing journey so far. 8)
"Smells like Rock N' Roll"
Embenny
Post by Embenny » Tue Dec 20, 2016 11:56 pm
Oh my goodness, you have completely revived a guitar that was on life support!
It's looking SO much better!
tubart
Post by tubart » Tue Apr 04, 2017 11:34 pm
jagstang wrote:Nice. Have you finished it yet? I have a similar problem with an old mustang body. Original competition car refinished with fiesta red. How have you removed the green finish? Did you made it all with hands or did you use some machines? I'm really new in restoring and don't know, how to start...
The only way to remove properly the paint is to use a scraper, or some sort of razor blade (be very careful with your hands using such tools : wear secured gloves).
A wood scraper is not expensive and very useful. Take time to remove the paint with this tool, and you'll perhaps have to polish the original finish then.
jagstang
Post by jagstang » Wed Apr 05, 2017 1:43 am
I used wet sanding paper. Got a good result. I did a own thread: http://www.offsetguitars.com/forums/vie ... 1&t=102112" onclick="window.open(this.href);return false;
UlricvonCatalyst
Post by UlricvonCatalyst » Wed Apr 05, 2017 3:50 am
This wins today's King of Threads award. Amazing transformation!
