1979 Gibson Marauder Restoration
cooterfinger
Post by cooterfinger » Sun Mar 17, 2013 4:08 am
I got this project in a trade with another forum member awhile back. I wanted to wait until I had enough progress to show before I posted since it’s probably going to take me quite some time to finish.
In my mind the key to this whole restoration would be the neck. If I could get the neck back in shape then everything else would fall into place.
The problems that needed to be addressed were.
One, these necks were finished natural in 1979, so the crappy red enamel spray paint would have to go.
Two, the headstock had a hole drilled in it where someone tried to repair it. The glue had started to separate on one of the headstock wings. It could have been steamed off and reglued but now it has a hole drilled in it where they were using a screw instead.
Three, it needs a refret and the fretboard has some nasty divots in it.
"Smells like Rock N' Roll"
cooterfinger
Re: 1979 Gibson Marauder Restoration
Post by cooterfinger » Sun Mar 17, 2013 4:09 am
Step 1: Strip the paint.
After one application.
After the second application the glue on the separated headstock gave way and fell off. That was a plus since I was going to have to remove it anyway.
You can see the serial number a little better now. There’s still some finish down in the stamp but it’s getting a little more legible.
Step 2: Headstock repair.
My wife had asked if I could cut her maple cutting board down a little because it was too big to for her to handle easily. I was happy to oblige. I cut a small donor block from the cutting board scrape to glue to the headstock. I routed one edge of the block perfectly flat and routed half of a tuner hole in it. It would have been a major pain to plug and redrill half a tuner hole if I hadn’t.
Cut and rough sanded to shape.
Tweaked a little and repair is done. While working on the headstock I also cleaned the paint out of the stamped serial number on the back. I took a mechanical pencil and lightly filled in the stamp to make sure I hadn’t messed them up any.
cooterfinger
Post by cooterfinger » Sun Mar 17, 2013 4:12 am
Well, the neck needs a lot of fret filing before I can do any finishing on it so I thought I'd move on to the body.
Before:
After:
Just kidding.
A new Alder body.
Templates.
cooterfinger
Post by cooterfinger » Sun Mar 17, 2013 4:21 am
Mockup of body complet with amber (earwax) switch tip.
noisepunk
Post by noisepunk » Sun Mar 17, 2013 10:21 am
Lookin' pretty sweet. Finish color?
They tried to give me advice, down at the record shop. I said "Sit down boys, this may come as a SHOCK. But alls I listen to, it's all freedom rock."
Pepe Silvia
Post by Pepe Silvia » Sun Mar 17, 2013 10:26 am
Very cool. I've always had a soft spot for these. Would love one in Pelham Blue or dark cherry
017493816
Post by 017493816 » Sun Mar 17, 2013 11:26 am
Reminds me of the prs starla.
Very cool.
PorkyPrimeCut
Post by PorkyPrimeCut » Sun Mar 17, 2013 11:37 am
;D
Heheh! You totally had me with the before & after shots!!
017493816
Post by 017493816 » Sun Mar 17, 2013 1:49 pm
PorkyPrimeCut wrote:Heheh! You totally had me with the before & after shots!!
I thought that was hilarious. ;D
cooterfinger
Post by cooterfinger » Mon Mar 18, 2013 2:08 am
noisepunk wrote:Lookin' pretty sweet. Finish color?
I was thinking of going with clear poly but I'm still not sure.
countertext
Post by countertext » Mon Mar 18, 2013 8:23 am
I let out an audible "Guhhhhh!" :wtf: as I leaned closer to my monitor...
:fp:
mulesing
Post by mulesing » Tue Mar 19, 2013 11:18 pm
leave the original body with that gnarly finish! lol
ludobag1
Post by ludobag1 » Sat Apr 06, 2013 12:20 pm
:w00t: citistrip works !
it change old alder body with paint in new body
i have believe :fp: :'(
:D
maximee
Post by maximee » Sat Apr 06, 2013 10:00 pm
Very keen to see how this turns out. I have a Gibson S-1, basically the same thing with different pickups. These are weird gibsons. Is yours also pretty heavy?
Mine also needs major fret leveling or probably better a refret. I've read somewhere that Gibsons of that era had crazy low frets from factory... Can somebody confirm this!?
I've never encountered frets that low in any guitar...
What are you going to do about the frets?
cooterfinger
Post by cooterfinger » Sun Apr 07, 2013 2:42 pm
maximee wrote:Very keen to see how this turns out. I have a Gibson S-1, basically the same thing with different pickups. These are weird gibsons. Is yours also pretty heavy?
I like the Gibson S-1 as well. Maybe I'll find one someday, this one kinda fell in my lap so I'm happy about that
even though it needs some work.
I've done some more work on the neck to take care of the worn frets and fretboard divots.
Step 1: Pull the frets. I used a soldering iron to heat each fret before pulling them.
Once they were pulled I took some fine sandpaper and a 12" radius block to the fretboard.
Step 2: Steam out the divots. For this I took an exacto knife with a new blade and lighty scored the divots along the grain. Then I took a damp handtowel and laid it on the divot and applied the tip of a clothes iron to the cloth for 3 or 4 seconds. I did this repeatedly to get the wood grain to swell and make the divot disappear. The deep divots are still there but they are much more shallow and can barely be felt when I run my fingers over them.
Step 3: Bleach out the stains. I used a little wood bleach to lighten the stains on the fretboard and on the back of the neck.
Step 4: New frets. I cleaned out the fret slots with an exacto and started the refret.
