So as I posted previously, I bought (ok, traded) for an all-original, untouched, black 79 Bronco- only to find that the seller had made the disastrous last minute decision to remove some sticker residue with industrial-strength adhesive remover. Totally destroyed the finish on the face of the guitar, and damaged the pickguard as well.
So after posting for a refinisher, I found Captain Crunch lives semi-locally, and was available. All good so far. Now I'm just deciding on a color, since there's no real need to keep anything original at this point.
Speaking of original, I'm definitely not a guy to dick with vintage guitars, mods and the like. Some things should be left well enough alone, I believe. Having said that, though, I think a (reversible) mod may be in order to make this Bronco stage-worthy.
The jack is pickguard-mounted, which is usually not a problem. But on these, the section of guard in question us very narrow and flimsy. I can actually imagine the pickguard snapping against the strain in the heat of a spirited performance. What plate could I use (Mustang?) that would be functional and attractive, yet be reversible? Since I have to have a new guard made anyway (TORT!), this seems like a reasonable option.
Please share your thoughts, opinions (never any shortage around here), experiences, and wisdom.
Thanks!
MODS: If this post would be better suited to MODS and PROJECTS, please feel free to move.
July 1979 Bronco Refin/ mod thoughts
- mongoose
- panoramic
Re: July 1979 Bronco Refin/ mod thoughts
put a widerange in the neck, toss a mustang guard on there, call it a day
eat kix, shit tastes amazing
- mongoose
Kix is full of corny goodness. And if you eat it, so shall be your sh*t!panoramic wrote:put a widerange in the neck, toss a mustang guard on there, call it a day
Will a 'Stang guard fit? That would certainly be an easy enough route if so.
- Fiddy
If you put a mustang control plate you're gonna have to drill extra holes tho'
