I'm refinishing a '65 Jaguar that I bought with a horrible refinish job. I'm doing it in Inca Silver with a matching headstock. I put the waterslide decal on today after painting/wet sanding/buffing the headstock, but I was wondering what the general consensus is on shooting over the decal with some clear? Did Fender just put them directly on top of the finished headstock and call it a day or did they shoot a coat or two of clear over them back in '65? Is it better to put some clear over it to protect it or will it be fine without it?
Thanks!
Question about waterslide decals and restoring an old offset
- Tweedledee
- wardpike
- Junkyard God
- Orang Goreng
Re: Question about waterslide decals and restoring an old offset
The first option. They easily scratch off, so you might want to go Ward's way.Tweedledee wrote: Did Fender just put them directly on top of the finished headstock and call it a day or did they shoot a coat or two of clear over them back in '65?
- Tweedledee
Thanks for the suggestions! I ended up following Danocaster's method:
Three lightly misted coats of clear over the decal. Then after it has fully dried (an hour or so) go over it lightly with some 0000 steel wool to knock down any unevenness. Worked great! Then I buffed it out with some 3m Finesse It to shine it up. Done!
