Pictures added.....Just one tuner away from completion....
PorkyPrimeCut
Post by PorkyPrimeCut » Tue Jan 30, 2007 8:20 am
....& its in the post (apparently).
:) Took its time but man was it worth it!! Thanks for all the help folks!!!  :)
Re: Pictures added.....Just one tuner away from completion....
Post by zhivago » Tue Jan 30, 2007 8:26 am
8) 8) 8) 8) 8) 8)
mynameisjonas
Post by mynameisjonas » Tue Jan 30, 2007 8:30 am
looking good!
Soiouz
Post by Soiouz » Tue Jan 30, 2007 8:30 am
It is gorgeous!!! Well done!
I really like that sunburst, and the 11 hole pickguard is fabulous! Nice tortoise!
Jay
Post by Jay » Tue Jan 30, 2007 8:35 am
Soiouz wrote: It is gorgeous!!! Well done!
Agreed on both counts!
daydreamdelay
Post by daydreamdelay » Tue Jan 30, 2007 8:39 am
my god that's beautiful  :?  :-*
congrats!!!
John Taverna
Post by John Taverna » Tue Jan 30, 2007 8:41 am
congrats man!
mynameisjonas
Post by mynameisjonas » Tue Jan 30, 2007 8:44 am
BTW, that guard looks almost totally flat to me.
Soiouz
Post by Soiouz » Tue Jan 30, 2007 8:46 am
mynameisjonas wrote: BTW, that guard looks almost totally flat to me.
Good observation! You're right!    My own 1965 is much more warped, and it is still very usable...  I wouldn't even try and flatten it out more, jazzheadmark. It looks just fine as it is!
PorkyPrimeCut
Post by PorkyPrimeCut » Tue Jan 30, 2007 8:49 am
Thanks. My only gripe it that there's a tide line where the neck meets the body. It looks like the body it came from was a different shape!! Does that fit with 59 to 60 JM's?.....
Anyway of cleaning it up or matching the relicing?? Its a very minor issue really.
PorkyPrimeCut
Post by PorkyPrimeCut » Tue Jan 30, 2007 8:57 am
The pictures actually make it seem better. Again, a minor issue though I guess!
luau
Post by luau » Tue Jan 30, 2007 9:01 am
Wow. Congratulations. I don't think I've seen all the before pictures, but I sure like the after pictures!
Bigger in sum than parts.
fullerplast
Post by fullerplast » Tue Jan 30, 2007 9:01 am
The tanline on the neck from the other body:
This is pretty common when changing necks. Although theoretically the bodies should be the same, there's almost always a small difference.
Some of it can be attributed to age and different properties of wood, shrinkage*, etc. And some of it has to do with the way the neck was shimmed in the pocket. Do you have a shim in there?
I always try to rub off the line with rubbing compound and then polish the area. It can usually be minimized if not removed entirely.
Your JM looks GREAT!  8)
* I WAS IN THE POOL!
;D
Q. Are we not men?
Soiouz
Post by Soiouz » Tue Jan 30, 2007 9:03 am
Wow... Those are big screws holding the rythm circuit switch!!  ???
As for the pickguard, your last pictures show the warping pretty well, but still, it doesn't look that bad.
Post by zhivago » Tue Jan 30, 2007 9:05 am
fullerplast wrote: shrinkage*,
;D
;D ;D ;D ;D ;D ;D ;D ;D
