1976 left-handed Precision needs tlc
sal paradise
Post by sal paradise » Tue Jan 30, 2024 1:25 pm
Couldn’t turn this down. Converted to right hand at some point in its life & a terrible paint job. A few knocks but generally in good shape. It’s light, the neck is nice a slim at the nut & it sounds exactly how I want a precision to sound.
Bought off a lovely dude whose house is basically a jumble of old amps, guitars & cables. Probably staring into my future :D
Plan is to strip it, remove the filler & send it to a friend with woodwork skills to do a proper repair on that right handed control cavity, then off for a refin. Think I’ll leave the rest as-is.
Seems to have a grey undercoat- any idea what colour this might have been originally?
I was thinking vintage white nitro for respray with black guard. Open to suggestions though.
HNB
Re: 1976 left-handed Precision needs tlc
Post by HNB » Tue Jan 30, 2024 1:26 pm
Oooo extra curvy on the back!
Christopher
Lilith Guitars
JVG
Post by JVG » Wed Jan 31, 2024 3:29 am
Olympic White would look good.
Why do some right handers feel the need to play a lefty upside down? Are they just trying to fuck up (or deprive us of) the relatively small number of instruments we have available? It messes with my head.
armensguitars
Post by armensguitars » Mon Feb 12, 2024 1:13 pm
Such a cool bass, hope you are able to do it justice! Agreed on the why make a lefty into a righty sentiment. My exception was once I found a lefty 70s strat neck, which immediately was paired to a righty body, as it was too cool not to.
Nudger
Post by Nudger » Tue Feb 13, 2024 1:51 am
This to me is perfect.
armensguitars
Post by armensguitars » Tue Feb 13, 2024 7:30 am
Is that from M&Ms? Looks amazing.
Nudger
Post by Nudger » Tue Feb 13, 2024 8:51 am
Yup, Finish by copacetic, on reverb 1969..
sal paradise
Post by sal paradise » Mon Mar 04, 2024 4:11 am
The refinisher wanted to do the repair work themselves, so I just sent off the body with finish still on. Due to the depth of alterations, we've been talking about best way to solve - current thinking is cut off the body at the line & replace. Will mean an offset join, but seems the way to save the most amount of wood.
MattK
Post by MattK » Mon Mar 04, 2024 4:16 am
That seems insane to me - lose the whole original corner curve and shaping? I would cut a veneer type patch and route the surface down. It won’t matter at all if some of the filler is left hidden inside. Or just leave it as is and make it smooth if you don’t need to see grain.
sal paradise
Post by sal paradise » Mon Mar 04, 2024 4:59 am
Veneer was the original plan. This is the problem- it’s beyond my understanding/knowledge though:
“due to the forearm contour needing to be recarved, part of the filled area would be exposed on the contouring. I don't think the infill section would successfully curve down over a new contour which is usually possible across a larger width, but tricky as a smaller section.”
MattK
Post by MattK » Mon Mar 04, 2024 10:34 am
Respectfully, that’s rubbish. If the contour needs to be redone (it didn’t look like it?) then carve the contour with the filler in place, rout out a patch area on the carved surface, patch and level. Even I could do that.
sal paradise
Post by sal paradise » Mon Mar 04, 2024 11:25 am
The contour would need shaping with a veneer, I think? That was the original plan.
JVG
Post by JVG » Tue Mar 05, 2024 9:19 pm
Yeah, unless you’re planning a translucent or clear finish, please don't go hacking chunks out of it.
Smooth it, finish it.
And for the person who originally made it right handed (and will never read this) - i’m still angry about it. Fucker.
hulakatt
Post by hulakatt » Fri Mar 08, 2024 6:00 pm
Although, as long as the wood is proper smoothed out underneath, under a metallic coat it won't much matter wether it's veneer or not.
Sherwood Green is lovely but I'm partial to Lake Placid Blue myself...
She/Her
sal paradise
Post by sal paradise » Thu Mar 28, 2024 3:56 pm
A little update. Decided to go with a replacement piece of wood due to complications, and on the recommendation of the person doing the work. Already looks way nicer :)
“Have made the new 'infill' piece and grafted it in.
Need to carve the forearm contour next, then continue stripping the existing paint from the back and edges of the body ready for the pore filling stage.”
