saving a Fender Decal before refinish
- arkivel
I have a metallic KO Marr Jaguar that I've been wanting to refinish for quite awhile. Id like to remove and save the transition era decal on the headstock. Theres no clear coat that I can see over the decal on the headstock. Is this possible? Can anyone chime in here?
Re: saving a Fender Decal before refinish
If it's on top of the clear coat, then you could theoretically get it off by carefully getting some water under the edges with a q-tip and slowly adding more until it's loose. The odds of getting it off the headstock and then handling the loose decal in a way that preserves it until you can put it back on are extremely low, though. Waterside decals are so fragile and fidgety that most people should keep a spare on hand when trying to apply even a brand new one. It's very easy to damage them and they're floating and sliding around. You'd essentially have to apply it two times, first onto a new piece of paper or plastic for storage, and then back onto the headstock.
Fender decals are super readily available, I'd save the trouble and apply a repro over the refin.
- FenderBob
What color do you want to go with? It seems those decals come off pretty easily, I've seen many where the JM signature is removed.arkivel wrote: ↑Tue Jan 31, 2023 1:18 pmI have a metallic KO Marr Jaguar that I've been wanting to refinish for quite awhile. Id like to remove and save the transition era decal on the headstock. Theres no clear coat that I can see over the decal on the headstock. Is this possible? Can anyone chime in here?
- arkivel
Thanks for the replies. The signature logo was removed before I bought it. I want to save the decal is because I assume it will look better than a repro. Not sure where to find a decent one.
As for colour I'm not sure. I'd like something that is a little rare. Likely a Metallic like fitemist silver, yellowed LPB. I also really like Fiesta Red.
- tequila_in_teacups
This is something I've wondered about, as I'd like to do a matching headstock on my JM at some stage. Not sure what the OSG protocol for posting links to repro decals is. Croxguitars has repro decals that look good, but hopefully someone with first-hand experience can attest to the quality or recommend somewhere else good.
Croxguitars is who I've used for the last few years and they've all been fantastic. Great range too.tequila_in_teacups wrote: ↑Wed Feb 01, 2023 11:51 pmThis is something I've wondered about, as I'd like to do a matching headstock on my JM at some stage. Not sure what the OSG protocol for posting links to repro decals is. Croxguitars has repro decals that look good, but hopefully someone with first-hand experience can attest to the quality or recommend somewhere else good.
- GreenKnee
I believe I've read somewhere that Fender shall supply replacement decals for damaged ones if you have COA, serial number etc. and you go through a Fender dealer.
I've never done this though so I may well be speaking bollocks.
- Bradley-Jazz
I can second that!johnnysomersett wrote: ↑Thu Feb 02, 2023 3:15 amCroxguitars is who I've used for the last few years and they've all been fantastic. Great range too.tequila_in_teacups wrote: ↑Wed Feb 01, 2023 11:51 pmThis is something I've wondered about, as I'd like to do a matching headstock on my JM at some stage. Not sure what the OSG protocol for posting links to repro decals is. Croxguitars has repro decals that look good, but hopefully someone with first-hand experience can attest to the quality or recommend somewhere else good.
All the cheeses....
- terminalvertigo
I came to post this..
scratch the decal.. call fender, get a replacement, refinish and apply the new one
- arkivel
I know nothing.. thank you
