1963 Fender Jaguar trem problems
Down Underground
Post by Down Underground » Tue May 06, 2008 2:45 am
After 10 years on the 65 Mustang I picked up a beater 63 Jaguar. (  If any of you are curious, the Jaguar is a far superior guitar than the mustang! ) Of course the Jaguar was missing the trem bar so I got a replacement from allparts. It does the job, however I have run into a problem. When I use the trem unit I get this nasty clanking sound from the vibrato arm mounting receptacle ( thats the part that sticks up through the top of the plate to accept the trem bar ) smacking against the top of the trem unit ( thats the part that bolts to the body and is stamped Fender) I have thought about sticking a rubber washer down there or using some tape but I don't think it will stay in tune. My guitar tech said "thats just the way they are". Any sugestions to fix this? Thanks!
fuzzking
Re: 1963 Fender Jaguar trem problems
Post by fuzzking » Tue May 06, 2008 3:39 am
Your guitar tech has no idea. The trem is supposed to be floating.
http://www.webrocker.de/jaguar/cms/2007 ... lo-system/
edit:
on re-reading my reply i think i might have come over a bit harsh. this was not my intent.
Jesus must be spinning in his grave.
mynameisjonas
Post by mynameisjonas » Tue May 06, 2008 7:19 am
sounds like you just need to loosen the spring (turn the large screw in the center of the plate counter clockwise).
