'77 Telecaster restoration project
raphaël
Re: '77 Telecaster restoration project
Post by raphaël » Sat Jan 18, 2020 5:28 am
Thanks !!
I've received the clear pickguard, from Kaish, everything is lining up perfectly. I'll try to find some time to try some options and to post pics in the week-end. I'll sure need some feedbacks ;)
And this morning I've received this early 80's (allegedly) Fender Pat Pend bridge plate. It's a very nice piece of steel, and again, perfectly in place on the body.
Question to Telecaster afficionados : do I have to shield the bridge plate itself or not? Or just the pickup cavity? Or don't need to do it at all?
I tend to shield everything on my guitars :blush:
solfege
Post by solfege » Sat Jan 18, 2020 6:15 pm
Re: shielding. The bottom plate on Tele bridges shield them, and the cover shields the neck pickup. I did no shielding whatsoever on my Broadcaster and it's been as quiet as my shielded guitars.
Apparently 50s era Esquires/Broadcasters/Teles were totally unsheilded from the factory. I do not know what was factory for Teles of your era tho.
raphaël
Post by raphaël » Sun Jan 26, 2020 2:47 am
I received the control plate and yesterday i've ordered the neck pickup:
The Lion King from Cavalier pickups.
I've contacted Rob yesterday at noon ("my" noon) and he replied right away, answered all of my questions and he pointed me to this pickup. So after 10 messages or so in a day, I bought it.
Very cool guy, very cool communication.
Can't wait!!
I just have to continue the finish work, to find the neck and buy/do the wiring and the tele will be done.
jvin248
Post by jvin248 » Sun Jan 26, 2020 5:01 am
I see you have ordered your neck pickup. I was going to suggest just get a blank Tele pickguard and wire just the bridge pickup for an Esquire Tele. Drive that around town for a while and then order the neck pickup if you really need it. You may find you don't :)
However, with a two pickup Tele, get a 4-way switch. they run around $11 online. That gives you both pickups in series as a stealth Les Paul Humbucker. It has become my auto-mod on any new Tele I'll play regularly.
Electrosocket jack retainer. Tune the jack so it sits just below the inner lip and you can basically stab the plug in the general area and the socket guides it home.
Switchcraft jack. You may want CTS as they are more common in Fender but I like Bourns pots.
A steel baseplate under the bridge pickup will reflect the magnetic field at the strings and give you a beefier output. It also shields the pickup. I have had success cutting house electrical box covers, octagon covers generally are 1/8th inch thick and that seems to work great.
I use aluminum flashing tape to shield all the cavities. Aluminum has slightly better shielding properties than copper. People use copper because it looks nice and 'costs more so it must be better' routine. Roll of Nashua tape is $8.
Shielded cable from the volume pot to the jack. This is about half the idle noise floor in a guitar, the other half is the cavity shielding.
Try out the control plate rotated 180deg so you have Vol-Tone-Switch to the rear. This is the Kirchen mod. Makes it easier to adjust the volume knob when playing without hitting the selector switch.
raphaël
Post by raphaël » Fri Jan 31, 2020 1:55 am
Thanks for your tips 8) !!!
I made some tests. For the pickguard.
#1 :
#2 :
#3 :
#4 :
#5 :
#6 :
#7 :
#8 :
What do you think?
If I go that route, I think my favorite is #2...and also, for some reason, I like the #8...which is weird as I like colors and flowers, while this one is very dark.
I also have another idea for the pickguard...it it works it will be pure awesomness !!!!
raphaël
Post by raphaël » Thu Feb 06, 2020 11:44 am
My second idea for the pickguard will work!! I'm super thrilled but it won't be doable before may, which is kind of a bummer. But that's ok, it involves fine craftmanship with incredible skills I don't have, so I have to wait!!!
DaddyDom
Post by DaddyDom » Thu Feb 06, 2020 1:29 pm
Wow - supercool! I like #2 and #8 but I like the idea so much I would probably like whatever you showed me ;)
What is your other idea?
Dd
Steadyriot.
Post by Steadyriot. » Fri Feb 07, 2020 2:52 am
That pickguard looks cool! I'd get annoyed with that zigzag pattern real quick though.
I second the idea of an electrosocket input and the 4way switch. Not only does the electrosocket guide your cable easier it also won't loosen like a normal Telecaster cup will over time (plus those are pretty hard to put in). One warning though, electrosockets won't always work with angled jack cables. On one of my tele's I can only use Neutrik's (which is fine because I always use Neutrik but it's a thing to consider).
The 4way switch adds an extra really useful sound to your palette. Worth the change from "traditional wiring".
I'd keep the brass plate on the pickup. Because of the plate and bridge a Tele doesn't really need any shielding on the bridge pickup but you can certainly shield it. I'd go with aluminum tape or some shielding paint.
Be careful with shielding the control cavity as parts can short out on it leaving you without sound. Be tidy in there.
Personally I hate the "Kirchen mod" but to each their own..! ;) It's a thing to consider if you ride the volume a lot. I kept bumping into it so I run the control plate normally.
sam
Post by sam » Sat Feb 08, 2020 1:34 am
I really like the alignment of pickguard #2
Post by Pacafeliz » Sat Feb 08, 2020 1:50 am
Yeah #2 is the winner for me too!
marqueemoon
Post by marqueemoon » Sat Feb 08, 2020 9:31 am
Another vote for #2.
solfege
Post by solfege » Sat Feb 08, 2020 8:10 pm
agree 2 is the one.
