Eko 350 Schematics
sts
Eko 350 Schematics
Post by sts » Thu May 02, 2019 11:09 pm
Hello,
I recently got hold of an EKO 350 guitar (at least I think that this is the model) which I decided worths getting restored.
The problem I came up with is that all the wiring is destroyed (has no wiring at all) so I cannot figure out how the schematics for the 4 button pickup selector system should be..
Here is a close up of the switch
Is anyone familiar with these sort of selector switches and their wiring?
Thank you in advance
timtam
Re: Eko 350 Schematics
Post by timtam » Thu May 02, 2019 11:35 pm
Your pics don't display. Load them to imgur or similar.
Looking at online pics, the rest of the wiring can't be too complex ... 2 pickups, 1 volume, 1 tone (?) ...
http://www.fetishguitars.com/eko/eko-300-serie/eko-350/
Finding a schematic could be difficult, so you may just have to work it out. Do you know what all the functions of the switch are ? ... Pickup 1, pickup 2, both in parallel, 4th position ? Series ?
Timtam (noun): Iconic Australian multi-layered chocolate biscuit.
sts
Post by sts » Thu May 02, 2019 11:59 pm
I believe that they are now visible?
http://cosm.gr/xzft14
http://cosm.gr/eoqwnp
http://cosm.gr/4tjvfa
About the wiring I believe it should be something like:
  • Bridge(hot) @ Switch Tip 1
  • Neck(hot) @ Switch Tip 2
  • Switch Tip 3(out) @ Volume pot(in) @ Tone pot
  • Volume pot(out) @ Jack
  • And everything else Grounded :
    Bridge(GND),Neck(GND),Switch(GND),Volume(GND),Tone(GND), Jack(GND)
but this doesn't exactly apply to a 4 button switch
I don't know the button functions..Maybe something like:
  • button 1: neck pickup
  • button 2: bridge pickup
  • button 0 : both ?? phase reverse ??
  • button M : killswitch ??
but this is just a guess :fp:
I really have no clue.
I've also found some pics online using capacitors and resistances on the tips, something like treble bleed wiring
agabinet
Post by agabinet » Sat Jun 08, 2019 5:18 am
I have a four pickup/six button Eko/Galanti p/u and switch set. I can post you some pics of the wiring that still exists . . . I am going to have to redo it all.
agabinet
Post by agabinet » Sat Jun 08, 2019 5:32 am
Here's a link to some pics of my four pickup/six button switch setup . . . you can see that there are four contacts at the end of the switch deck. Pressing the different buttons creates contacts with different combinations of the pickups. I am assuming that the signal goes from there to the tone and control pots and then to the output jack. HTH
https://link.shutterfly.com/ePOtUkVYlX
Ari
