66 Jazzmaster rescued from parting-out
will
Post by will » Sun Jan 08, 2017 9:04 pm
So, I spotted a '66 Jazzmaster getting parted out on ebay. ...the pictures were really bad, and the descriptions were as vague as any I've ever seen.
For instance, here's the entire three-word and one date description of the body:
"1966 fender jazzmaster body"
...and the neck:
"1966 fender jazzmaster neck"
"buy it now" got the best of me and I picked up the body and neck, and the seller ended the other auctions and sent along the switch, pots, and neckplate - that was nice and unexpected. Luckily, it arrived pretty quickly, the pickups worked (6.0K, 6.8K), and the neck wasn't warped.
Here are a few pictures after I spent some time cleaning it up and adding some parts (pickguard, knobs, a slider switch, output jack, and wiring.)
...looks like it started out sunburst
Also, I had a chance to straighten out the tremolo plate while everything was apart for cleaning.
I forgot to take a picture after the gaps were filled in in the cloth wiring!
will
Re: 66 Jazzmaster rescued from parting-out
Post by will » Sun Jan 08, 2017 9:18 pm
Next up, I need to dress the frets, glue down the binding that is popping up, and find something to make a new inlay for the fingerboard - I was going to try something called "Acrylester" that looks like it might be a good match for the plastic stuff Fender used to use.
Post by zhivago » Sun Jan 08, 2017 10:36 pm
Excellent save!
looking forward to see more! :)
PorkyPrimeCut
Post by PorkyPrimeCut » Sun Jan 08, 2017 11:56 pm
Agreed. This looks great already. Quite an unusual but very cool colour!
Post by Pacafeliz » Sun Jan 08, 2017 11:58 pm
That is SO cool, congrats!!!
PorkyPrimeCut
Post by PorkyPrimeCut » Mon Jan 09, 2017 12:01 am
Actually, if it's no trouble, can you measure the length of the thread on the vibrato arm, where the plastic too should be, and take a close up pick of the other end (that pops into the tail piece?
Axolotl
Post by Axolotl » Mon Jan 09, 2017 1:25 am
Love this so much! :? Thanks for saving it! If you find a good replacement material for the second block let us know. Such an awesome find.
PorkyPrimeCut
Post by PorkyPrimeCut » Mon Jan 09, 2017 1:58 am
Axolotl wrote:If you find a good replacement material for the second block let us know. Such an awesome find.
It's a long shot but you might want to message Ben (theworkoffire). Hopefully he won't mind me mentioning this. He had a sheet of stuff he planned on using. It had a repeat pattern but you could easily cut it at different ares/angles & you'd never know. Perhaps he'd be willing to cut off a small portion?
Also, if you find something suitable but it's too pale you can rub brown dye over it, then rub it straight off. That'll "age" it slightly (I did it on a build of my own).
will
Post by will » Mon Jan 09, 2017 10:43 am
PorkyPrimeCut wrote:Actually, if it's no trouble, can you measure the length of the thread on the vibrato arm, where the plastic too should be, and take a close up pick of the other end (that pops into the tail piece?
Here are a few pictures. The line that's about 2mm from the end of the bar is actually wear from the bar spinning in the collet - when the bar is used less, it it pretty much tapers directly from 4.2mm to 4.66mm at the end.
will
Post by will » Mon Jan 09, 2017 10:46 am
PorkyPrimeCut wrote:Agreed. This looks great already. Quite an unusual but very cool colour!
It is kinda like Ocean Turquoise, I think. ...though I don't know if that was the intention of whoever painted this one! I was already planning on refinishing a guitar to Ocean Turquoise (the paint is in the mail) but I think I'd like to play this one for a while before I take it apart to do a proper refinish.
will
Post by will » Mon Jan 09, 2017 10:47 am
Axolotl wrote:Love this so much! Thanks for saving it! If you find a good replacement material for the second block let us know. Such an awesome find.
I'll post some information once the stuff I'm trying arrives in the mail. The material Fender used is a little strange - it is quite translucent, so sometimes the maple beneath really shows through!
antisymmetric
Post by antisymmetric » Mon Jan 09, 2017 1:04 pm
:-* Really good to see the reversal of fortune for this guitar- it's fallen into the right hands! Keep us posted. :)
will
Post by will » Mon Jan 09, 2017 1:36 pm
...so I had a Coronado II neck waiting for a project and I started thinking: "I wonder what would happen if I stick some good masking tape to the inlay and give it a sharp tug?"
The inlay material is strange stuff - lots of bubbles! It looks like it is some sort of cast material. I wonder what the inlay process was like at Fender.
Now I have a complete Jazzmaster and a Coronado II in need of an inlay.
Post by zhivago » Mon Jan 09, 2017 1:53 pm
Hehehe! that's a quick and cool fix! 8)
Some things are meant to be! :)
I have a real soft spot for this era Jazzmaster....my first one (which I always refer to as a '67), was actually a late '66 guitar...October of '66 if I remember correctly.
It had a great neck profile...very fast...mine was CAR...body refin, but the headstock was original (and fairly trashed) 8)
PorkyPrimeCut
Post by PorkyPrimeCut » Mon Jan 09, 2017 2:16 pm
will wrote: Image
Ha! Great (and pretty light) work!!
(thanks for the arm measurements too).
