eupat wrote: "sealer" (je connait pas le terme français)
Je crois que le terme est "scellant" ou "apprêt-scellant".
ledsenthe older brother wrote: Jag fattar inte nåt!
"Fetchez la vache !"lastlol wrote: Sorry for the extensive use of French in my thread, but this way it was easier for me to give renaud tips about lacquer cans you can find in France and the experience I had with them !
Fetchez la vache !
for sure it helps! thank u so much!painted wood wrote: I know you are past this phase and I'm late to the thread, but I lightly sand my sealer coat with 400 grit until it is completely mirror smooth, then spray primer and a day later I lightly sand my primer with 600 grit until it is mirror smooth. After each phase I wipe the body clean with naptha on a paper towel, to remove all contamination and/or dust. Then I spray my paint, let it dry for a day, wipe clean with naptha, spray one can of clear, wait another day, wipe the body with naptha, and spray the second can of clear.
I only pass over an area/side one time, never multiple passes or this causes runs. I spray one pass on the sides, wait a couple minutes, the front, wait a couple minutes, the back, wait a couple minutes and repeat.
I think the pinholes are due to you spraying too wet of a coat and air getting trapped under the paint and trying to escape. I assume you are spraying multiple passes at one time.
I would wait a few days and then lightly sand back your color coat with 600 or 400 grit and get the surface nice and smooth and shiny (reprepped) and then proceed with the color again.
Your passes should be kinda wet, but keep the can moving at a steady pace, and never repass and area, until 5 minutes or so has gone by, then apply the second pass over the entire body. You only want enough color to completely cover the body.
I hope this helps.
