Jaguar / jazzmaster bridge evolution in pre/post cbs
Guitarman555
Post by Guitarman555 » Mon Jan 01, 2024 1:25 pm
Does any body know if there was any evolution in bridge from 1959 to 70´s? Especially a change that affected the sound? I am on a hunt for a vintagejag / jazzmaster bridge for my jag and not sure if and when Fender made a change. In other words till what year is the bridge of same quality as pre-cbs? Thanks mates.
I just know that Fender experimented with more fine threads on the first 2 strings (e,h) in around 1962, but that is not important.
Marc
Re: Jaguar / jazzmaster bridge evolution in pre/post cbs
Post by Marc » Sat Jan 06, 2024 1:29 am
I don’t think they changed. They are all hit and miss. I’ve had some that worked well for what they are with the usual setup techniques and others that were not great at all and from the same year approx! I think it’s more design flaws than actual quality of materials or manufacturing.
Guitarman555
Post by Guitarman555 » Sat Jan 06, 2024 12:25 pm
So you think the material was the same over the 60´s and 70´s years? If so, only problem could be worn out threads or an extremely buzzing piece.
Marc
Post by Marc » Sat Jan 06, 2024 12:31 pm
I doubt they changed supplier or materials. Blue loctite can help with the rattles and obviously setting the bridge high and the neck shimmed.
Guitarman555
Post by Guitarman555 » Sat Jan 06, 2024 12:39 pm
Sounds good. So if it rattles you would use blue loctile for all 12 small legs threads right? I didn´t know that those are the little legs that are source of the rattle. I had a mustang bridge too which is without legs and it rattles too. Or you mean perpahs the 6 threads that hold each metal barrel in the tuning position?
Marc
Post by Marc » Sat Jan 06, 2024 12:49 pm
I also wrapped insulation tape around the two bridge posts that sit in the thimbles. This helps. It makes a tighter fit but still allows the bridge to rock.
I never bother with this anymore and just use a Staytrem bridge. If you look at pro players using vintage models hardly anyone uses the original bridge. It’s just too much hassle.
tqi
Post by tqi » Sat Jan 06, 2024 1:23 pm
level3
Post by level3 » Mon Jan 08, 2024 4:18 am
Finer threads were part of the original design, as far as I know. Not sure when they changed it, but around 62 seems about right.
The only other difference I have seen is in the area where you can access the screws in the bridge posts. Older bridges have more rounded, dome-shaped openings, while the later ones are flatter.
Guitarman555
Post by Guitarman555 » Sat Mar 02, 2024 2:15 pm
Thanks for this information guys.
Guitarman555
Post by Guitarman555 » Sat Mar 02, 2024 2:16 pm
So material/soumd should stay the same till 1980 right?
GreenKnee
Post by GreenKnee » Sun Mar 03, 2024 1:22 am
Yep, this is correct.
Original bridge design with domed holes:
Later design with no dome:
Guitarman555
Post by Guitarman555 » Sun Mar 03, 2024 2:25 am
Many thanks bro. I am thinking about purchase of this one, seller told me late 70's, so can mean 79 or 80..
GreenKnee
Post by GreenKnee » Sun Mar 03, 2024 2:37 am
What year is your Jag from?
There isn't much point in paying a premium for that bridge you're looking because a modern repro will look like that after a couple of years of hard use anyway.
The only time I'd pay a premium for a vintage bridge is for one of the original ones with the domes and then only if it was to restore a guitar to original spec.
Guitarman555
Post by Guitarman555 » Sun Mar 03, 2024 3:12 am
New production sounds to my ear very different to the old bridges. I searching it for my 64 jag, I am not a collector but old vintage bridges sound to my ears much better than the reissues. It is probably because the material is of course different now adays. Btw this bridge below is 1964?
Marc
Post by Marc » Sun Mar 03, 2024 1:03 pm
At the end of the day whether vintage or a reissue they are all a bit janky. If you can hear a difference then go for it.
