WWYD? (What Would You Do)
- jazzbro
So I recently got this '59 Jazzmaster with a few issues. I love the fact that it's mostly original and want to keep it that way as much as possible. But I also have some setup and some parts issues with it.
1. The tuners and bridge are not original. I'll replace the tuners cuz these just don't look good. Everything else appears to be original with the probable exception of -
2. The nut which is notched way deep, which MAY be because -
3. The frets are really low. They/re not notched, just really low. I don't know if they came this way (not a JM expert), were notched and leveled once or twice or...? Which brings me to -
4. The bridge. It's likely a Japanese replacement for the original bridge. It's missing some height adjustment screws and if that and some other TLC takes care of the buzzing, proper string placement, etc that's fine. If not, I'll be going with one of the replacement bridges. Would like a StayTrem for the function, look and fingerboard radius but they're very difficult to get here. Complaints about Mustang and string width make me shy away from that. Mastery - maybe some day.
My main decision is which scope do I take on first - (i) do the tuners and nut replacement and live with that for a while, possibly trying out a Mustang bridge at the same time because it's easy, relatively cheap and comes with the right fb radius or - (ii) the whole thing - go for the re-fret right away, cut the nut to match, possibly go for the Mastery even though it's not remotely period or function-correct really if I can't find a StayTrem, and of course the tuners.
I'll do what I'll do, but... what would you do?
Re: WWYD? (What Would You Do)
Tuners first. A guitar that won’t stay in tune is useless.
Nut with a refret unless it’s unplayable as-is and there’s enough fret life left to push out a refret a few years.
Bridge last. It’s low hanging fruit, but won’t have a profound effect on how the guitar plays.
How does it actually play in its current state?
I missed the part about missing height adjustment screws on the bridge.
I’d deal with the bridge first in that case.
A fixed radius bridge on a 7.25” board with old frets may not be a problem solver in itself though.
- Telliot
I’d source the bridge and tuners, find a local luthier that knows what the hell they're doing, bite the bullet and do everything at once. Bridge, tuners, refret, nut, setup. Done. Trying to do it piecemeal would drive me absolutely crazy. At least this way it’s done and ready to enjoy. I’d never want to play it, otherwise.
- jazzbro
Action is very very low to sort of match the frets and the nut. It actually plays okay if you like it that low. I don't. Other than that it plays okay.
I like the neck - to me it feels a bit Ibanez-ish and I like their necks - but it's not what you would call thick and between that and the low frets it just feels a bit wimpy.
I'd get everything sorted out at once as Todd suggested, then try and find a vintage bridge or a Staytrem.
- zhivago
- reserves
Where’s the pictures ?
- UlricvonCatalyst
If it is from a Japanese JM or Jag it'll have narrower posts (the bits that sit in the thimbles). I'd suggest you look for some comparison pics before you toss it, just in case it's an original.
Also it sounds like a shim under the nut might be all it'll take to raise the action to something you'd be happy with.
Agreed. My gold guard sat for over a year, barely played because the frets were toast. I had it setup with big flat wounds on the original bridge. It just wasn't getting used. Then, I had it refretted / nut shimmed / Staytrem bridge added all at once and play it daily. It's amazing how much a refret can positively change a vintage guitar.Telliot wrote: ↑Mon Jun 22, 2020 3:24 pmI’d source the bridge and tuners, find a local luthier that knows what the hell they're doing, bite the bullet and do everything at once. Bridge, tuners, refret, nut, setup. Done. Trying to do it piecemeal would drive me absolutely crazy. At least this way it’s done and ready to enjoy. I’d never want to play it, otherwise.
- JVG
Recommended bridge, if you can’t get a Staytrem, is the Johnny Marr:
https://darrenriley.com/store/fender-j ... 712971000/
- jazzbro
That actually looks like a really good option.JVG wrote: ↑Tue Jun 23, 2020 1:03 pmRecommended bridge, if you can’t get a Staytrem, is the Johnny Marr:
- Telliot
- Mechanical Birds
If you can afford it I’d say refret
If it’s an inevitability and not in the way that yeah, any guitar when played enough will need a refret kind of way, but in the ‘it basically doesn’t have frets’ kind of way
It sounds like it needs all of that stuff done but weighing it as ‘ok replace all the surface parts’ and it still needs a refret, yeah go for broke from the get go
