Bass VI tuner button broke
Tele295
Post by Tele295 » Thu Sep 06, 2018 6:35 pm
Restringing my 65 L-series Bass VI, and the button on the D tuner broke and now spins freely.
This is a players instrument and has had parts changed over the years. Sometime in the late 70’s/early 80s, the Kluson in line tuners were replaced with Fender F cover tuners. Different hole pattern. Both sets of holes can be seen on the neck. I’ve had the guitar since the late 80’s.
So where can I get a replacement? If I have to change the whole set back to Kluson style, that’s ok, but I can’t seem to find any replacements. Of course, the string channels are larger than they would be for regular guitar tuners.
Please?
The natives are restless tonight......
oid
Re: Bass VI tuner button broke
Post by oid » Thu Sep 06, 2018 9:29 pm
Bass VI strings fit in my AVRI Jazzmasters tuners, those are klusons, at least the set of slinky strings I got did. So standard klusons may do you just fine.
Edit: are they klusons on the AVRI? I really should know this since I play it daily.
sookwinder
Post by sookwinder » Thu Sep 06, 2018 11:48 pm
yes they fit, I used that type when I built my bass VI some years back... but the shaft diameter is dramatically smaller than the tuners made for Bass VIs
N0_Camping4U
Post by N0_Camping4U » Fri Sep 07, 2018 6:22 am
I cannot help, but in regards to your last post, the diameter is different, but do the strings fit? Does it affect anything?
Eric Harris: I’m sorry I have so much rage, but you put it on me.
sookwinder
Post by sookwinder » Fri Sep 07, 2018 9:47 pm
Yeah the strings can be strung with no issues.
oid
Post by oid » Fri Sep 07, 2018 11:45 pm
You would most likely have finer tuning and a slight increase in the risk of string breakage at the tuning posts. String life should still be plenty good, I played the Bass VI set on my Jazzmaster for around a year and that set was still going strong when I switched back to guitar strings. The finer tuning most do not really notice and few that do are bothered by it.
