Price check: White Which Hat knobs.
- AWSchmit
I have a set of old stock white which hat knobs on a project that I decided to disassemble and scrap out. When I got them they were NOS. Not from a 65 JM or anything. Curious what the going price for these would be as I have no real need for them now. Thanks.
https://photos.app.goo.gl/aLCbYSSxYHsbKuVJ7
- Mechanical Birds
Re: Price check: White Which Hat knobs.
No idea but that guitar looks sickkkkkk
The last pair I bought back in 2014 were $32USD including shipping from US->AUS.
- AWSchmit
Thanks. I'm surprised no one can chime in one a more recent sale... Once the supply dried up they must have stopped changing hands... Maybe my set can help establish the current value by putting them on ebay or something..
Thank you... Unfortunately the body is heavy as hell and the neck has developed a bit of a twist... So I'm going to try to sell the body, and see about straightening the neck... We'll see.
I've been looking at a set for one of my Jazzmasters and I think I have seen them available for a little over $25. Maybe $28 or so.
Let us know if you sell, I might be interested. Although the posts on my Jazzmaster and splined and not smooth bore, so I am wondering if these will even work on there well. I should have thought of that when I did this but then again I don't think that Fender was making proper witch hats when I re-did the electronics.
- Mechanical Birds
I used knurled pots in my JMJM and used these knobs. There’s the slightest bit of wobble but they’re tight and not going anywhere. Works fine
- AWSchmit
Is the $25 set you're talking about vintage or modern repros? I know fender makes a really nice repro now.Larry Mal wrote: ↑Mon Jun 11, 2018 6:20 amI've been looking at a set for one of my Jazzmasters and I think I have seen them available for a little over $25. Maybe $28 or so.
For the reproductions- are you selling actual vintage knobs? If so I missed that, apologies for the bad information.
- AWSchmit
No prob. For all I knew vintage ones have came down in price, so I thought I should check. Thanks.
- PorkyPrimeCut
Only last week I sold my last NOS set for £25.
A little UK perspective for you
- parry
Yep. Same. If you orient the screw so it tightens in to the split, they tighten up perfectly and doesn't crush the tines together, but rather pushes it slightly open, making better contact.Mechanical Birds wrote: ↑Mon Jun 11, 2018 6:29 amI used knurled pots in my JMJM and used these knobs. There’s the slightest bit of wobble but they’re tight and not going anywhere. Works fine
- solfege
Another option: https://www.philadelphialuthiertools.co ... es-5-pack/parry wrote: ↑Mon Jun 11, 2018 3:07 pmYep. Same. If you orient the screw so it tightens in to the split, they tighten up perfectly and doesn't crush the tines together, but rather pushes it slightly open, making better contact.Mechanical Birds wrote: ↑Mon Jun 11, 2018 6:29 amI used knurled pots in my JMJM and used these knobs. There’s the slightest bit of wobble but they’re tight and not going anywhere. Works fine
I got a set for my JM a couple of years ago when they first became available as reissue. I think they were about $20 - $25.
definitely added some mojo to the look.
- Acoasma
26 dollars 3 months ago.
8 dollars shipping from us to eu.
Still about 20-30% cheaper that here.
Theres about 39eur + shipping
