Why 1959 jazzmasters sound much darker than 1964 ones?
- Guitarman555
Why 1959 jazzmasters sound much darker than 1964 ones? Is it question of slabboard, or quality of wood? Or some changes in pickups? What do you think?
- Lock
Re: Why 1959 jazzmasters sound much darker than 1964 ones?
Pickups. The rosewood stops being slab in ‘62 and gets thinner in ‘63, but I can’t see that changing tone noticeably.
- Guitarman555
- Kent
- Axolotl
If I recall correctly, it has something to do with enamel wire used for pickups in 1958 - 62.
From the Jim Shine website:
"1958-1962 The pickups were wound with plain enamel wire. They were potted in an alcohol activated material. The windings fill up the entire bobbin and often slightly rub the pickup cover. The magnets were hand beveled and the magnets barely stick out beyond the cover. On the bottom the magnets stock out quite a bit and have a heavy bevel. Both neck and bridge pickups have black and white cloth wire and the fiber for the coils is made from black material.
1962-1964 The winding wire appears to change to bondable Formvar and is still potted with the alcohol activated material. The winding style changes during 1962 from a 'scatter wind' to a more even wind. "
For this reason also the 1959 wire looks redder than later ones.
For me 58-61 are the golden years...and I’ve always put it down to the black bobbin pickups with the early winding material.
And specifically ‘59 tort guards.. you get the super slim neck the perfect pickups and lack of gold guard which to my ears harshens the tone slightly..
- Lock
I’m not an expert on vintage, I just know that for vintage voice JM pups you hear of darker 59 ones (like an SD antiquity I) and then mid sixties are brighter ones (seems the preferred voice, antiquity IIs).Guitarman555 wrote: ↑Mon Mar 19, 2018 2:35 amThanks, Lock, so you think they changed pickups from 1959 to 1964? Slaboard is obvious, but i haven´t heard about pickups change..
I assumed it was part of the shift from the guitar’s initial intention of competing with hollow jazz guitars towards a more standard Fender sound, but that’s heresay.
- HH1978
Pickups, definetely. I have two home build jazzmaster. One has original 1959 pickups, wound with plain enamel, the other has 1965 pickups, wound with Formvar. The one with 1959 pickups is a bit darker, and hotter, even though both guitars have 1965 necks, and aftermarket bodies.
I've also been winding my own pickups for three years now, using both wire types, and there's definetly a difference, probably due to plain enamel having a thinner insulation, and thus a thinner overall gauge for the same gauge of copper wire, which would add capacitance.
- HH1978
The difference in those resides mainly in the type of magnets (alnico II for Antiquity I, vs alnico V for Antiquity II). It might emulate the original voices pretty well, but the difference in the original ones is somewhere else, as they were all alnico V.I’m not an expert on vintage, I just know that for vintage voice JM pups you hear of darker 59 ones (like an SD antiquity I) and then mid sixties are brighter ones (seems the preferred voice, antiquity IIs)
- skink
I used to have a sunburst (alder) 59, a blond (ash) 61, and a refin (alder) 66, and I always assumed the 59 and 66 were darker because of alder bodies. The 59 was the darkest. I sold the 59 and the 66 long ago, but I still have the ash 61. I've had it for close to 20 years now. I love that guitar and its brightness, so I always chocked up my preference for it to the ash body.
- soggy mittens
I had read the 59 magnets lost more of the pull over the years and that is why they sound darker, read this in an explanation of the SD Antiquity Is and IIs. Aged magnets.
- fuzzjunkie
My early '62 Jag sounds noticeably darker compared to the '63 & '64 that I had and any post 90s Jag as well, just to throw more fuel on the winding, bevel, magnetic fire.
It depends whether you look at GGs or early tort, too. My experience with anodized guards is that they also cut a little bit of high end (as do most types of shielding around a pickup).
- HH1978
They might have lost a part of their charge compared to new pickups, but I doubt it would really make a significant difference between 1959 and 1965 pickups.I had read the 59 magnets lost more of the pull over the years and that is why they sound darker, read this in an explanation of the SD Antiquity Is and IIs. Aged magnets.
