Recommend me a decent preamp for less than 150€
- Pingu
So my shitty Behringer mixer, which I was basically using as a preamp, broke down a few weeks ago. I'm planning to record some vocals with a friend next week, but I'm sort of strapped for cash at the moment. Right now I'm leaning towards the Art Tube V3 or the Presonus Tubepre.
"Anything that doesn't take years of your life and drive you to suicide hardly seems worth doing." - Cormac McCarthy
- diversionends
Re: Recommend me a decent preamp for less than 150€
It may be pushing your budget slightly...
Joe Meek threeQ
They are extremely good. Really pristine sounding and it has more than adequate gain to drive an SM57/58. That will be the main issue with the preamps you listed. They will be fine for condenser mics but suffer on dynamics unless it's a loud source (like snare). They seem to sell new on ebay for around £150, which obviously exceeds your 150 euro limit. You could maybe get a second hand one within budget. Not something you'd be rushing to upgrade
Joe Meek threeQ
- mezcalhead
- Admin
I have one of those .. it's OK, I guess you could say it's a good preamp as cheap preamps go.Pingu wrote: Art Tube V3
I think Rob has one which he used for the latest Idiotbear album, which sounds more than decent to me.
Thanks, Jon.
I actually have the Art Tube Project MP with USB (bit of a mouthful). It rules, although you have to ensure the source you're recording is quite loud to get a decent signal-to-noise ratio. It doesn't really love being cranked. Hissy.
- Pingu
Uhm, isn't the main purpose of a preamp to boost the signal?idiotbear wrote: Thanks, Jon.
- northern_dirt
I have the dual channel meek EQ... the Mq5 or whatecver EQdiversionends wrote: It may be pushing your budget slightly...
Joe Meek threeQ
But I have to say, its a pretty colourful and most meek stuff seems to be device..
Not shitting on it, just saying, its kinda a corner one might not want to back themselves into
when they don't have other options available.
'cleanest, best pleasure'
Sure, but not THAT much. I'm talking about REALLY cranking. See my old 'mic hiss' thread. Brad explained it all, like a very specialist Clarissa.Pingu wrote:Uhm, isn't the main purpose of a preamp to boost the signal?idiotbear wrote: Thanks, Jon.
- Orang Goreng
idiotbear wrote: Brad explained it all, like a very specialist Clarissa.
- the older brother
I have a Studio Projects VTB1 - a one channel valve (12AX7) pre amp with a variable blend of tube in the mix.
It's really great, but I haven't actually used it for some time due to lack of space on my desk and the pre amp/trim in my UA25 is OK for quick demo recordings (I used it for the vocals on the track called Breaking the Jaw on the last recording done with my old band)
It's in your price range I suppose (I cought mine for five years ago for 1600SEK), but it's only one channel. A good sounding one though.
- Orang Goreng
Given how you probably want to replace your mixer, eventually... I got this a while ago, which is well-under € 150.
I used the Behringer version of that Art pre-amp before. Oddly enough, the Behringer one is more expensive, for some reason. When I found out they, and Art, and some other makers, put fucking LEDs behind the tube to make it seem like it actually does something, I got annoyed, so when my Behringer broke down (well, it didn't, it was my recording software playing up, but anyway) I got the Soundcraft. Sounds nicer as well, i.e. a bit less coloured.
- Pingu
Actually, I don't need a mixer at all.Orang Goreng wrote: Given how you probably want to replace your mixer, eventually... I got this a while ago, which is well-under € 150.
- diversionends
What does your second sentence mean? I kind of know what you mean about the colouration, although I use the eq to help attune the preamp to different mics. I might be wrong but I think low used one for drums & guns... probably with pretty excellent mics though... sorry... off topic rambling...northern_dirt wrote:I have the dual channel meek EQ... the Mq5 or whatecver EQdiversionends wrote: It may be pushing your budget slightly...
Joe Meek threeQ
- northern_dirt
Its a very musical Preamp.. which means it colours the sound..diversionends wrote:What does your second sentence mean? I kind of know what you mean about the colouration, although I use the eq to help attune the preamp to different mics. I might be wrong but I think low used one for drums & guns... probably with pretty excellent mics though... sorry... off topic rambling...northern_dirt wrote:I have the dual channel meek EQ... the Mq5 or whatecver EQdiversionends wrote: It may be pushing your budget slightly...
Joe Meek threeQ
If you are going to get just one preamp, it should be something as clean as possible..
This will allow for more control of the sound as it will be more true to source..
That all said, if you have room for more than one preamp, then colour can come into play..
- fuzzjunkie
true color:Its a very musical Preamp.. which means it colours the sound..
[/img]
way out of your price range! mine too! sorry for the thread hi-jack, I just can't use cheap pres and comps anymore.
sleeping on a bed of fuzz and feedback
- soundhack
here's a very nice pro-quality clean preamp under 150 - but obviously you'll need more than this pre!
http://www.seventhcircleaudio.com/T15/T ... _about.htm
