Re: Do Logic guitar effects hiss?
- debian
I noticed whenever I record a guitar in Garageband and add an effect it creates this background hiss/noise upon playback, especially on distortion sounds. I know it's the effects, because if I record w/ no effect it's not present. Since garageband is entry level, I was wondering if Logic has this same hangup? Hopefully someone will know what I'm talking about...
- Maggieo
The hiss you're hearing is probably coming from your audio interface or your guitar- computers give off loads of RF interference and noise and if you've got the gain cranked on a plug-in it's like playing with a Fuzz Factory in aen's "haunted rehearsal space," only without the Twins' play-by-play.
I've found the effects in Logic to be pretty quiet and pretty awesome. Here's a track of mine where I ran my Jazzmaster with distortion and ring modulation and delays:
"No Promises"
"No Promises"
- Pingu
What effects are you using? A certain amount of background noise is of course unavoidable with distortion.
I have found that scanner vibrato + rotor cabinet + tape delay is the key to sonic bliss.
"Anything that doesn't take years of your life and drive you to suicide hardly seems worth doing." - Cormac McCarthy
- debian
Thanks. To further clarify, the problem with the hiss only gets super noticeable when the guitar on that track isn't playing. I may have the effect turned up too loud in all honesty, but I guess I thought the effect would get quiet when not playing, and not create this hissing sound.Maggieo wrote: The hiss you're hearing is probably coming from your audio interface or your guitar- computers give off loads of RF interference and noise and if you've got the gain cranked on a plug-in it's like playing with a Fuzz Factory in aen's "haunted rehearsal space," only without the Twins' play-by-play.
"No Promises"
- Maggieo
Try adding a noise gate to the channel strip- that'll keep things dead quiet when you're not playing.debian wrote:Thanks. To further clarify, the problem with the hiss only gets super noticeable when the guitar on that track isn't playing. I may have the effect turned up too loud in all honesty, but I guess I thought the effect would get quiet when not playing, and not create this hissing sound.Maggieo wrote: The hiss you're hearing is probably coming from your audio interface or your guitar- computers give off loads of RF interference and noise and if you've got the gain cranked on a plug-in it's like playing with a Fuzz Factory in aen's "haunted rehearsal space," only without the Twins' play-by-play.
"No Promises"
- debian
It's definitely the distortion effects that are the worst. They end up coming off as so cheesy sounding because of it. I am considering better software, since I know Garageband is just a sonic "sketch pad", but it's hard to even sketch when most distortion sounds so annoying. I know you were recommending guitar rig. I hope something has better digital distortion out there.Pingu wrote: What effects are you using? A certain amount of background noise is of course unavoidable with distortion.
I'm seriously tempted to just use my Mesa tube preamp since it has a recording line out.
- debian
Ok, thanks. I'll give that a try.Maggieo wrote:Try adding a noise gate to the channel strip- that'll keep things dead quiet when you're not playing.debian wrote:Thanks. To further clarify, the problem with the hiss only gets super noticeable when the guitar on that track isn't playing. I may have the effect turned up too loud in all honesty, but I guess I thought the effect would get quiet when not playing, and not create this hissing sound.Maggieo wrote: The hiss you're hearing is probably coming from your audio interface or your guitar- computers give off loads of RF interference and noise and if you've got the gain cranked on a plug-in it's like playing with a Fuzz Factory in aen's "haunted rehearsal space," only without the Twins' play-by-play.
"No Promises"
- Maggieo
You can use the Channel EQ to dial out some of the hiss, too.
Good luck and post some tunes when you've got 'em done!
