Urgh ... audio interface woes
ChrisFFTA
Re: Urgh ... audio interface woes
Post by ChrisFFTA » Tue Mar 24, 2020 3:20 pm
Yeah that helped tremendously
What cables would work and do they need to be stereo both ends?
somanytoys
Post by somanytoys » Tue Mar 24, 2020 8:35 pm
I don’t know much about studio monitors (don’t have any).
If the interface’s output signals and/or the monitors’ input signals are balanced, you would need 2 TRS cables.
If neither of them are balanced, would think that 2 normal TS cables would work, since it’s only 1 channel each - left & right.
You may well want to wait for someone else to give a more experienced answer.
-David
ChrisFFTA
Post by ChrisFFTA » Tue Mar 24, 2020 11:48 pm
I’m grabbing some TRS cables and will how that goes
Strangely now I can’t here any recorded pieces nor can I hear any of say the built in drum loops etc
Super weird....
ChrisFFTA
Post by ChrisFFTA » Sat Mar 28, 2020 5:06 am
Bought new cables and all sorted. Thanks everyone
ChrisFFTA
Post by ChrisFFTA » Tue Apr 14, 2020 12:46 am
Another noob q... you can’t plug into your pedalboard and then into an audio interface and expect it to sound good, right?
MayTheFuzzBeWithYou
Post by MayTheFuzzBeWithYou » Tue Apr 14, 2020 1:02 am
I‘d say it depends how you do your recordings...
I use a Focusrite Scarlet2i2 -with GarageBand and I‘m pretty sure you can record with Ableton while using Garage Band‘s amp selection (or even import the one in the other) - if you don‘t have any amp plug-ins you could probably use some kind of „amp modeller pedal“ like those cheap Harley Benton/Joyo American/British Sound - or like the ones of Boss/Fender (Bassman59, etc.) in the end of your chain.
somanytoys
Post by somanytoys » Thu Apr 16, 2020 7:05 pm
Speaking only from the standpoint of having tried to use a cab sim after an effects chain only (even with an amp in a box), it needs a preamp to give it some life.
-David
budda12ax7
Post by budda12ax7 » Sun Apr 19, 2020 8:13 am
I have the focusrite scarlet 4 input thing....
I have used my pedals straight into the focusrite......mostly for modulation. Sounded fine. I use Ampire and Bias FX for my cab sim and amps....it does work, you just need to play around with it.
