Basic question about mic noise
DesmondWafers
Post by DesmondWafers » Fri May 31, 2019 10:37 am
So I've been using an sm57 and 58 for a few years and recently decided to step up to a better mic. I decided I wanted an LDC first, so I got an AT4033 used off reverb. Anyway, I'm not sure if it's my lack of knowledge concerning condenser mics, but I've been having some issues. The mic works perfectly...sometimes. Unless the cable is positioned perfectly, it gives me a loud noise, very similar to the noise that you get when you touch a guitar cable that's plugged into an amp without a guitar attached. I'm using the same interface and mic cable that I use my other mics on, so I don't think it's either of those. Perhaps I am just used to the more robust shure mics, but this seems a lot more finicky than I anticipated. Is it the mic or am I simply using it incorrectly?
Larry Mal
Re: Basic question about mic noise
Post by Larry Mal » Fri May 31, 2019 11:08 am
Nothing about that is as it should be, I am going to speculate that it kind of sounds like you are having a grounding issue with the microphone.
Maybe unscrew the capsule and see if anything looks loose in there? Put up a picture and maybe that can help.
Those are good mics, though.
DesmondWafers
Post by DesmondWafers » Fri May 31, 2019 8:07 pm
I left for work right after posting this, just took it apart. Yeah, you were right. One of the wires connecting to the xlr pins was almost completely off. I soldered it again and now it's all good. For my uses (acoustic) it is a rather significant step up from the sm57 I've been using for a looooong time.
Larry Mal
Post by Larry Mal » Fri May 31, 2019 8:48 pm
57s are awful on acoustic guitars... glad to help.
somanytoys
Post by somanytoys » Sat Aug 10, 2019 8:20 am
We need to get you fitted for a cape, Larry.
(Edna: “No capes!!!”)
-David
Larry Mal
Post by Larry Mal » Sat Aug 10, 2019 8:30 am
So, now we've got the mic sorted, didn't you get a D-18 recently? I was kind of hoping to hear more about that.
DesmondWafers
Post by DesmondWafers » Sat Aug 10, 2019 9:35 am
I did, a few months back actually, I just haven’t been on here as much recently. I’ve been selling/trading a lot of acoustics the past few months and it honestly blows every other acoustic I’ve ever had away. So much so that it made my 00018, which I loved, completely redundant.
