MIXING ADVICE NEEDED : VOCODERS?
Cpe4spd
Re: MIXING ADVICE NEEDED : VOCODERS?
Post by Cpe4spd » Thu Apr 11, 2019 4:17 pm
"Oh no! Do you know what he' doing next ...Some sampling!"
Noel Gallagher :derp:
Sit Back, Shut Up and Hold On!
øøøøøøø
Post by øøøøøøø » Thu Apr 11, 2019 6:32 pm
Larry Mal wrote:
Thu Apr 11, 2019 12:49 pm
I know what he's doing.
What a great track and video. I had never seen the video before!
Telliot
Post by Telliot » Thu Apr 11, 2019 7:39 pm
Seriously great. ❤️
Jaguar018
Post by Jaguar018 » Fri Apr 19, 2019 6:27 am
@telliot, Larry just threw down the gauntlet. Let's hear your Earth, Wind and Fire cover album. 8) :ph34r:
Telliot
Post by Telliot » Sat Apr 20, 2019 7:31 am
StevenO wrote:
Thu Apr 11, 2019 10:26 am
What's your plan for the vocoder? As a replacement for standard vocals? To compliment and/or support standard vocals? Or do you want them to be treated/listened to like one would a non-verbal instrument, like a clarinet or flute or other?
I’m using the Vocoder as more of a textural treatment in the choruses, more than anything. I wanted to try something that made me uncomfortable, which worked, but I ended up liking it more than I thought I would. I mean, it’s no EW&F, but that’s a pinnacle I’ll never reach.
¯\_(ツ)_/¯
DrQuasar wrote:
Thu Apr 11, 2019 9:59 am
When do we get to hear the track? I always enjoy your stuff.
Cheers!
This is my latest mix. No idea if it’s any good — I’ve lost all objectivity at this point. :D
Anyway, hope you enjoy it.
Further Into You
Larry Mal
Post by Larry Mal » Sat Apr 20, 2019 8:56 am
I think it sounds great! Good song, great mix, Todd. Good show!
Telliot
Post by Telliot » Mon Apr 22, 2019 6:48 am
Thanks, Larry! 8)
chrisrnps
Post by chrisrnps » Wed Jun 26, 2019 10:39 am
That sounds great!
Re: the original post: it’s not you, it actually is pretty difficult to get a vocoder sound to sit in a mix like that, particularly with most plug-in vocoders, and particularly with a pre-recorded vocal track - it’s much easier to “perform” the vocal input while hearing its effect on the synth input in real time, which means a hardware vocoder or recording through the plugin “live” (which can be tricky.)
Tips: “speaking” the vocal input part rather than singing it, and don’t be afraid to get weird with enunciation and diction - you’re going for the formant / EQ / spectrum of the sound, the pitch is nearly irrelevant. The sound used for the “synth” part is also very important - having something full-range, bright, and unfiltered (like a sawtooth synth sound or string machine sound) usually works well.
And don’t forget to play with sources that aren’t vocal / synth! Using a drum part to “vocode” a synth, guitar, white noise, or other part can also be cool.
'Excellent! A little more practice will make you a regular whale. Now, if I may trouble you to unlace my back and front plates two holes more, I'll try that fascinating bend that you say is so easy. Won't Painted Jaguar be surprised!' ~ Rudyard Kipling
