mic help
- s_mcsleazy
mic help
so yeah, i stay on a busy street, there is a hospital, police station and fire fighters all on this street. i've noticed in some of my recordings, even when close mic'ing that you can still hear the sirens of the emergency vehicles, anyone got any tips on how to mic but maybe not have the sound of police chasing down jack the jakey?
- Trout
Re: mic help
Is this when you record vocals? I’ve recorded my best vocals in my car actually.
Trout
Trout
#sitdownrock at https://staffanandersson.bandcamp.com/album/det-hemliga-namnet
- s_mcsleazy
Re: mic help
vocals.... ha. nope. no singing for me. nah, its from guitar.
- Trout
Re: mic help
I guess we can drop the car idea then
- oid
Re: mic help
Use the least sensitive Mic you can get away with, have the source as loud as you can get away with so you can keep the preamp volume low.
- UlricvonCatalyst
Re: mic help
Line6 has the answer.
Re: mic help
I’d say Two Notes or Universal Audio have the answer.
- jorri
Re: mic help
turn up the amp
put material in between amp and sound source? which is from all directions probably if your windows are closed...I have recorded with a duvet over the amp and mic before (watch out for overheating) it won't be the best acoustics but if the other option is a bedroom it may in fact be better than that.
You'd probably still get low rumble, like motorbikes speeding past etc. but that could be minimised with a high-pass filter. You could potentially automate such a filter or use multiband compression somehow (i'd probably do automation since it won't be occuring all the time) and dial it in a bit more extreme that way if its just momentary...worth a try anyway.
- jorri
Re: mic help
depends if you have a nice soundproof rumble proof car. Mine is crap and actually i'm sure there are a few holes in it somewhere.
But it seems like an interesting place to record, i always practice in there and it would be an interesting mood.
I think Thom Yorke recorded some of the Kid A sessions vocals in a car not sure if he was actually driving at the time.
- Trout
Re: mic help
I have both a 7- seat Ford and a small Skoda. The Skoda is by far the best vocal booth
- s_mcsleazy
Re: mic help
thanks for the tips.
- DeathJag
Re: mic help
I record dialog for a living, and a motorcycle, plane, sirens, and big trucks are almost always sound problems. But FAR less so with less sensitive mics like the SM57.
Building a low budget baffles to put in front of the windows can make a big difference with mid and high freqs, but they have to be thick (at least 6” of thick foam between 1” pieces of plywood) and SNUG to the wall to help with low freqs. Even then you’ll hear most anything under 80Hz or so.
Given your situation, you could baffle your windows, use a 57 facing directly away from the noise, and turn the amp up loud.
Last thing would be something you’ve surely thought of, which is waiting to record until the quietest hours...
