Re: your effects setup?
Everyone needs a stompbox.
marqueemoon
Post by marqueemoon » Sun Feb 23, 2020 4:34 pm
Current state of the board for my new band. I may be switching to my Bassman setup soon. If so the DIY footswitch will get swapped with a Malekko trem.
Singlebladepickup
Post by Singlebladepickup » Sun Feb 23, 2020 8:20 pm
somanytoys wrote:
Sat Feb 22, 2020 10:08 am
Yeah, I have one of those Alessi (I think it is) PA-80s or whatever it is. It’s loud enough, and kind of small and easy to move around.
Yes, we should, that would be cool.
I also have an old (80’s) Peavey PA (500XR or something like that) with the 2 tower speakers, but it doesn’t work well. It clips out badly and probably needs a good bit of gut work. I’m not very good at that, and I’m not going to work on it or get it fixed - you could have it if you want it.
Cool, I asked about the PA because I'm not that into hauling gear and a PA would allow me to avoid it altogether. Ive mostly been playing synth through a mixer into monitors, and that stuff is probably not going to move except in the unlikely event I was performing. I can't fix stuff and I'm probably too lazy to get something fixed. I'd probably drop it off and forget about it like I do occasionally with dry cleaning
Post by zhivago » Sun Feb 23, 2020 11:29 pm
New band = new board :)
natthu
Post by natthu » Mon Feb 24, 2020 1:04 am
Double HOF for stereo? (dual mono).
Do you have trouble syncing them or is the difference what makes it good?
Post by zhivago » Mon Feb 24, 2020 2:19 pm
Just different settings to toggle from...I tried stacking them at some point...it was ok...nothing mind-blowing :)
Zork
Post by Zork » Mon Feb 24, 2020 2:35 pm
Can't wait to post my new pedalboard. It's not yet finished but I could finally make use of my old EHX Micro Synthesizer again and the whole thing is fucking sick.
Post by s_mcsleazy » Tue Feb 25, 2020 3:51 am
if you're using a microsynth. im guessing the board is the size of a surf board
Shadoweclipse13
Post by Shadoweclipse13 » Thu Feb 27, 2020 8:13 am
I was watching a video where a guy (Nick Reinhart? Maybe someone else?) was playing a Boss DD-5 and was using the hold function really short, and it sounded awesome. I started looking into a few of the Boss digital delays, and think that I might like either a DD-5, DD-6, or DD-7. I started looking into the differences between each as they all have some similarities, but I was wondering if any of you guys have any opinions of one vs the other on any of those specific 3 models?
Last edited by Shadoweclipse13 on Thu Feb 27, 2020 9:51 am, edited 1 time in total.
parry
Post by parry » Thu Feb 27, 2020 8:27 am
I was watching a video where a guy (Nick Reinhart? Maybe someone else?) was playing a Boss DD-5 and was using the hold function really short, and it sounded awesome. I started looking into a few of the Boss digital delays, and think that I might like either a DD-5, DD-6, or DD-7. I started looking into the differences between each as they all have some similarities, but I was wondering if any of you guys have any opinions of one vs the other 9n any of those specific 3 models?
A friend lent me a DD7, insisting I try it - reluctantly, i did. I liked it a lot more than I was thinking I might. I picked one up and eventually moved it along in favour of my analog delays. Once I got playing with the band I'm currently in and our sound changed (lots of amp reverb), I knew I needed a tighter, cleaner delay so I picked up another DD7. This time, I used it in conjunction with an external tap I built and it's not been off my board since. I'm crazy for the dotted-8ths this thing does. The looper is also handy to have - I use that quite a lot more than expected. Have an RC-1, but keep the DD7 on my board and use that, instead. I recently also picked up a new DD8 and use the two in conjunction. OH. MY.
The DD8 has a ton of "modes" (shimmer, hold, glitch, etc) and they all sound pretty great, but I find it falls a bit short of the DD7 in the straight-up, classic delay category - which is why the pair of them is pretty special. I think it's pretty close to having the best of every boss delay.
Here's the link that sold me on trying the DD8:https://www.youtube.com/watch?v=yvvBQUV3e5g
Shadoweclipse13
Post by Shadoweclipse13 » Thu Feb 27, 2020 3:10 pm
Wow, that thing has some really good sounds! I'd actually worry that I wouldn't use a ton of them. On guitar, I prefer delays with an analog voicing, but I tried all of those pedals on bass, and it didn't do much for me. My bass board has changed a little since then, but I thought that a digital-voiced delay might be the trick for bass. I'm gonna have to find a used one locally to see if I can try it in person.
Haustnótt
Post by Haustnótt » Sun Mar 01, 2020 11:22 am
Current configuration. Finally satisfied – hope it lasts a while. The ABY is for routing the signal from the octaver to the organ simulator and through the rotary (which has great cabinet simulations) to the PA. Power supply is the great Voodoo Labs Mondo, which is both the most versatile and the quitetest I've had.
Byrði betri berrat maðr brautu at en sé mannvit mikit
Zork
Post by Zork » Sat Mar 07, 2020 12:30 am
soggy mittens
Post by soggy mittens » Sat Mar 07, 2020 4:12 am
are you referring to this?
https://youtu.be/w2KpIsHNBk8?t=45
Zork
Post by Zork » Sat Mar 07, 2020 8:19 am
Ok, that was quick. I just watched that episode of the JHS show about flangers and now I'm completely obsessed with that Pearl FG-01. Found one locally and hope to put it in place of the BF-2 soon. What a pedal! :?
Singlebladepickup
Post by Singlebladepickup » Sat Mar 07, 2020 9:48 am
Those moogs, that vi :?
The Pearl Octaver is on my board, I bet their flanger is great as well
