Re: your effects setup?
Everyone needs a stompbox.
Futuron
Post by Futuron » Tue Feb 20, 2018 5:52 pm
mackerelmint wrote:
Tue Feb 20, 2018 5:27 pm
A can opener?
Doubles as a slide and a spare pick.
Also you can clean your fingernails with it, shim, capo, remind the keyboard player who's boss, and in the case of an emergency open that box of altoids on the left
onebigholiday
Post by onebigholiday » Tue Feb 20, 2018 6:55 pm
A can opener?
More specifically... a bottle opener. It doubles as a wedge to pull the pedals off the board. The stuff that Blackbird uses is like epoxy.
Last edited by onebigholiday on Wed Feb 21, 2018 7:54 pm, edited 2 times in total.
mackerelmint
Post by mackerelmint » Tue Feb 20, 2018 6:56 pm
Ahhhhhh, OK!
That makes sense. ;D
Ashtray floors, dirty clothes and filthy jokes
NBarnes21
Post by NBarnes21 » Thu Feb 22, 2018 4:06 pm
Just finished up this board for some upcoming shows with my project Plutinos. Pretty jazzed how everything ended up fitting onto the small board, it was not intentional and just ended up working out. I run both my acoustic and electric through this with the A/B box switching to the DI for the acoustic.
ImageIMG_0123 by TenaciousN8, on Flickr
2010 OSG Fantasy Football Champ
Sid Nitzerglobin
Post by Sid Nitzerglobin » Sat Feb 24, 2018 6:41 pm
I wound up acquiring a couple of new ones from one of my friends ( a Caroline Shigeharu and a Carbon Copy Deluxe) and finally cabled up a setup on the silver PT Jr. last night/this afternoon:
guitar > EP Booster > PolyTune 2 > 1 Loop Box (R) { Shigeharu IC Fuzz > Barbershop Millienium OD } > 1 Loop Box (L) { Alien Echo > Tractor Beam > Ghost Echo > Monument > Carbon Copy Deluxe > Topanga } > Buffered Splitter > amp(s)
I wound up spending most of the evening checking things out and tweaking through the Maz Jr. and OR50 w/ a handful of guitars and I'm really grooving on it so far. It could really use another bypass loop for the Alien Echo > Tractor Beam > Ghost Echo bit of the path but I haven't been able to Tetris a way to squeeze another one on. It would probably be a more ergonomic and roomy setup if I moved it over to the PT2.
The Shigeharu is pretty surprisingly awesome sounding to me w/ the gain rolled down and stacked up w/ the EP and Barbershop into the amps dialed for edge of breakup. It produces a really tasty aggressive, sharp edged, and punchy heavy dirt w/ really good clarity/chord articulation. The momentary for the octave is fun to play around w/ but I might flip it over to always on mode and just dial it in and out w/ the knob as desired, it would be a more useful switch for me if it was latching when you had it switched to the octave mode.
I haven't jumped into the more advanced features on the Carbon Copy deluxe yet, but the tap, divisions, external control of modulation, & bright switch all seem very welcome to me for fine tuning the delay so far. The general character of it sounds nigh on identical to my beloved regular CC just w/ a whole lot more on the fly flexibility. It will most likely get most of its use in the doubling and slap zones, but sounds very nice doing 1/4 notes and longer too.
MechaBulletBill
Post by MechaBulletBill » Tue Feb 27, 2018 8:38 am
First time in about a year I've used a board without the Broadcast on it.
Kihtaristi
Post by Kihtaristi » Thu Mar 01, 2018 4:00 am
My board for this year has been:
Changed Mad Professor Ruby Red Booster for Voodoolab Sparkle Drive in December.
loudwizard
Post by loudwizard » Thu Mar 01, 2018 5:48 pm
Think I’m set right here for a while.
Shadoweclipse13
Post by Shadoweclipse13 » Fri Mar 02, 2018 11:37 pm
Love It! Haven't played a Belle Epoch yet, but I like the way it sounds, and the Hummingbird is my favorite pedal!!
loudwizard
Post by loudwizard » Sat Mar 03, 2018 6:56 am
thanks! I love the Belle Epoch Deluxe-still trying to figure out if I have any use for the expression pedal stuff, but it just sounds GREAT - first tape-like delay I've used that makes me not want to drag my old Echoplex around. and the Hummingbird is my least used pedal, but it sure does its thing well - some times I just have to get all Spacemen 3. :)
Shadoweclipse13
Post by Shadoweclipse13 » Sat Mar 03, 2018 7:58 am
Hell yes 8) I use the super fast mode 3 on the Hummingbird quite a bit, and I also use it in conjunction with a delay (and sometimes phaser too!) to get a very good Uni-Vibe approximation. Lot of fun!!
my bloody television
Post by my bloody television » Wed Mar 07, 2018 7:44 am
just added the mini vent II yesterday...loving it so far
Unicorn Warrior
Post by Unicorn Warrior » Wed Mar 07, 2018 7:12 pm
That minivent looks intriguing. I really want to try a stereo set-up one day
onebigholiday
Post by onebigholiday » Thu Mar 08, 2018 1:40 pm
That's a sweet setup!
Post by my bloody television » Fri Mar 09, 2018 6:35 am
Yeah it’s great. I don’t always have the opportunity to play out with a stereo setup but it’s nice to have the option. Stereo really opens up that pedal particularly...the spread is really three dimensional. I’m surprised I went for a pedal without any knobs as I love to tweak but this thing sounds fantastic as is. There are some preset parameters you can change by cycling through the foot switches but I haven’t experimented with that yet
