Re: Setup of the day
Everyone needs a stompbox.
crazyzeke
Post by crazyzeke » Thu May 02, 2024 2:09 pm
Flurko wrote:
Thu May 02, 2024 12:58 pm
Squier Bronco bass when I need some lower noise
Is that some kind of Hot Rail in it? Don't think I've seen that done before.
Flurko
Post by Flurko » Thu May 02, 2024 2:33 pm
Yes, it's a random AliExpress copy, I wasn't huge into the strat type pickup that was in there and with the tape wound strings I needed something that was less susceptible to noise. I have a mustang control plate on the way so I can run this bass without a pickguard and try a few direct mount pickups.
crazyzeke
Post by crazyzeke » Thu May 02, 2024 2:48 pm
It's a pretty clever idea, using a rail pickup. Does it reproduce all the low end stuff a bass needs properly?
Flurko
Post by Flurko » Thu May 02, 2024 2:57 pm
I guess it does ? I'm not a specialist in bass amplification, one of the studios at the place we play at has some kind of big ugly bass amp and even a guitar downtuned can sound massive with the proper setting on it. I would have to compare the bronco to a more standard bass in that kind of amp to have an idea of what it does bad or wrong.
I mostly used the fretless guitar tonight because their wasn't any bass amp available, and it is very enjoyable to play. I don't have a great ear for pitch so I'm probably not perfectly Intonating but we improvised some great interlocking dual guitar parts and it sounded pretty fine.
therizzla
Post by therizzla » Thu May 16, 2024 11:07 am
Quilter 101 Mini (non-reverb) mounted to a Block Dock 12 loaded with a WGS ET90 (x2) & Quilter 201 mounted to a Block Dock 15 w/ stock Steelaire 15”.
reverb.
Salfaromeab
Post by Salfaromeab » Fri May 17, 2024 3:26 am
Cool Shag sticker, met him a few years ago at Surfer Joe, lovely bloke
Through the tallest wave, into outer space.
therizzla
Post by therizzla » Fri May 17, 2024 5:06 am
It felt appropriate for a sparkle Danelectro Bass VI. I picked that up at his gallery in Palm Springs, it was the only thing I could afford at that time!
reverb.
