Re: The D.I.Y. thread.
Everyone needs a stompbox.
chrispop
Post by chrispop » Fri Jun 28, 2019 11:11 am
hi all,
first post after a long time lurking in the shadows...
here's a few pedals i've built over the last few weeks.
top row: 2x basic audio zippy fuzz clones (one for a friend), ghost effects lunar incarnation clone in old transistor radio, modded coloursound one knob in vintage intercom (original switch changes input caps)
bottom row: silicone tonebender, bsaic audio scarab deluxe clone, 2 different, heavily modded bosstone based thingies.
all of them on stripboard and finally i'm at a stage buildquality wise that i'm ok to show them...
hexes
Post by hexes » Fri Jul 05, 2019 9:11 pm
thank you! i have all the parts on hand to build one for my enzo. assumed it was more involved.
krib wrote:
Thu Jun 27, 2019 7:40 pm
125€ in europe, for a fancy box with 3 resitors, 4 switches and stereo jack :D
By Gila_crisis @ freestompboxes
Post by s_mcsleazy » Sun Sep 29, 2019 9:28 pm
well i've mentioned this on and off but the first few MuLove prototypes are done. it's nothing special. it's basically a mid boost with lot's of gain on tap if you need it. but it can also go super clean too.
storyboardist
Post by storyboardist » Thu Oct 31, 2019 6:31 am
I've been working on this thing ages. Finally worked all the bugs out and it's sounding awesome. Pedalization of the Sunn Beta Bass preamp, the SunnBeam!
effectslayouts.com
thirtydirtybirds
Post by thirtydirtybirds » Thu Dec 05, 2019 7:31 am
I am VERY curious about that betabeam.
Georg Figél
Post by Georg Figél » Wed Jan 15, 2020 4:50 pm
did a subtle refinish to my Volume Pedal:
I've also put together this video of the building process:
https://youtu.be/1rCuJzwqXYQ
My fancy guitar videos on YT:
https://www.youtube.com/c/GeorgFigél
Leave a Like on Facebook:
https://www.facebook.com/georgFigel
felixvaughn
Post by felixvaughn » Thu Feb 06, 2020 6:23 pm
very nice! how did you do the glitter? wet or dry?
storyboardist
Post by storyboardist » Fri Feb 07, 2020 8:16 am
Custom parametric mids EQ (Catalinbread VarioBoost clone) with soft touch switching in a one-off wooden/bent steel enclosure. Made it for a buddy and his band's name/logo is on the badge. The badge is 3D printed in resin and painted.
An in process shot:
Guts:
Finished:
I'm going to redo the name badge as the screw holes were just a bit off and made the lower edge bend upwards, not to mention gashing the lower line of text with a screwdriver. But he's excited to use and they're going into the studio in a few weeks, so hopefully it'll be a useful tool in that process. Here's their Spotify link if anyone fancies a listen: https://open.spotify.com/artist/6vHP2UiHTuZKRBVhtx2nFe
effectslayouts.com
Georg Figél
Post by Georg Figél » Sat Feb 08, 2020 3:54 am
I did it dry
and then sprayed a mist coat of clear over it to avoid blowing the glitter away.
And then I did proper clear coats over it
Shadoweclipse13
Post by Shadoweclipse13 » Sat Feb 08, 2020 9:15 pm
An in process shot:
Guts:
Finished:
Dude! With the wood sides, that is just incredible!!!
greens
Post by greens » Fri Feb 21, 2020 12:33 pm
An in process shot:
Guts:
Finished:
Yeah, that came out great!
wingnutkj
Post by wingnutkj » Sat Mar 21, 2020 2:26 am
Given the Coronavirus situation (I'm working from home and staying out of people's way), I've had some time to complete another pedal kit:
It's a Jed's Peds Katzenkonig Rat+Boost. The pattern on the case is from a swatch of fabric I have, which I photographed and messed with on my computer. The case was sprayed with Plasikote fast dry enamel, but I couldn't get my transfer technique to work over it, so I sanded the top back and did the transfer on bare metal, covering with a coat of Halfords spray lacquer.
I use the laser print transfer technique (this is as much for my own future reference as anyone else's):
  • The print is designed in Scribus (a freeware DTP app) - making sure to get the holes for the pots and switches lined up correctly.
  • It is mirrored and printed onto glossy paper using my cheapo laser printer (it is very important to remember to mirror it!).
  • I trim round the image so that there are "tabs" that I can fold down and tape to the side of the pedals, to hold it in place.
  • Use a hot iron to transfer the print, making sure to press down firmly and cover the whole surface.
  • Run under cold water to cool the case and thoroughly soak the paper.
  • Once the paper is saturated, I rub away the paper with my fingers, using gentle pressure.
  • This leaves just the toner stuck to the metal, and I give it a polish with 12000-gauge micromesh
  • At this point it looks great, but as it dries, it alarmingly turns a powdery-white colour.
  • To fix this, I spray with Halford's clear lacquer. I've found that gently warming the case before spraying helps get a really glossy coat.
Kenny
somanytoys
Post by somanytoys » Sat Mar 21, 2020 8:54 am
Those are some damn nice diy pedals. If they sound half as good as they look (and I’m sure they do), they must be awesome.
I should be trying to finish my MOD tube reverb kit while all this is happening. It was just kind of an aggressive project for someone with very minimal skills at this sort of thing.
This is helping to feed that drive, thanks to everyone for positing the pics and helpful info.
-David
wingnutkj
Post by wingnutkj » Sat Mar 21, 2020 1:01 pm
Mine sounds a bit like this:
https://i.imgur.com/evizdNg.mp4
I'd a lot of fun messing around with the various options (input level, Rat gain, output gain, Rat filter and clip switch). I'm enjoying the complete change in tone between the two clipping options (LEDs and 1N914s).
Kenny
Post by s_mcsleazy » Tue May 12, 2020 12:31 am
quick question for those who design pedals. i'm wanting to add a low-pass/high pass filter to a fuzz pedal i'm working on, where would be a good place in the circuit to fit it in?
