New pedal - knobs don’t turn.
Everyone needs a stompbox.
JVG
Post by JVG » Tue Jan 14, 2020 1:15 am
Ok, here’s a random one....
I bought a Keeley Delay Workstation, slightly impulsively, but the deal was good.
Just received it today, took it out of the box and began to fiddle, as you do. Strangely, the reverb and delay mode selector knobs (the two at the left) do not move. Not at all. Not in either direction, even when a fair amount of force is applied.
It’s brand new.
I’ve written to Keeley to ask for ideas, but wonder if if anyone has encountered this before. It’s possible that there is a simple explanation, and that i am an idiot for not working it out, but at any rate it has me baffled! :(
I haven’t included a pic, because there’s really nothing abnormal to see.
Ideas?
Cheers
J.
Shadoweclipse13
Re: New pedal - knobs don’t turn.
Post by Shadoweclipse13 » Tue Jan 14, 2020 1:54 am
Are those switches analog (have a set spot they click to) or are they rotary encoders (can rotate infinitely, usually showing an LCD display for whatever is selected)?
JVG
Post by JVG » Tue Jan 14, 2020 3:06 am
Analog, with set spots they click to.
I tried powering the pedal up, in case somehow there was some kind of lock on them, but no luck. Very weird.
mackerelmint
Post by mackerelmint » Tue Jan 14, 2020 3:25 am
Try taking the knobs off, and seeing if there's something amiss with now they're attached? I'm having a hard time imagining why they would be, but it's worth taking a look under the hood.
Not that you'd be at all pushing the boundaries of good taste by simply returning it and demanding one that works.
jorri
Post by jorri » Tue Jan 14, 2020 10:47 am
Only had this (builder) when internally the pot is just seized up, broken. Like a spring popping out a rotary switch, or someone dropped solder inside a pot. It might be the mechanism of the indent where it clicks in thats stuck.
Solution usually new pot, no way of not destroying it more,if building.
If i bought it id return it!
Other is that yes, knobs could be too low so get stuck but i would assume this just scapes and not completely stuck against force. Worth trying to remove them if it wont void any warranty.
marqueemoon
Post by marqueemoon » Tue Jan 14, 2020 11:48 am
Really weird.
I wouldn’t touch it until you hear back from Keeley, or contact the seller about returning it.
If the pots are soldered to the board you could do some damage if you really go gorilla on it.
JVG
Post by JVG » Tue Jan 14, 2020 5:08 pm
Thanks for your comments - it’s comforting to know that i wasn’t missing something stupidly obvious.
I got a reply from Keeley’s team. They suggested these knobs may have got pushed down during transit and therefore stuck, and that i should try a again to turn or remove them. I was a bit doubtful because the box and packaging showed no sign of transit-induced trauma.
Anyway, having effectively been given the ‘green light’ to remove them, i applied a touch more force, at which time the shaft broke clean in half :fp: I was somewhat surprised to see that it was a plastic shaft.
Even after this, i tried shifting the stump of the shaft - no movement whatsoever.
So, this will be getting sent back! How bizarre - especially considering that both the rotary switches had seized up this way.
I’m still confused as to how this could happen. I’ve never had any trouble with Keeley stuff in the past.
Cheers!
J.
marqueemoon
Post by marqueemoon » Tue Jan 14, 2020 5:27 pm
Wow. WTF?
jorri
Post by jorri » Tue Jan 14, 2020 5:51 pm
JVG
Post by JVG » Tue Jan 14, 2020 5:59 pm
Oh yeah. It certainly is fucked now!
I’m not overly concerned, because i’m sure it’s just a one-off, and i should be able to get it exchanged without drama. Pretty weird, huh?
J.
Shadoweclipse13
Post by Shadoweclipse13 » Tue Jan 14, 2020 10:44 pm
Wow. That's nuts. I figured that the knobs were pushed down too far, as I've had a pedal or two like that myself. That pot is frozen! Hopefully Keeley won't have any issues repairing or replacing the pedal for you.
JVG
Post by JVG » Wed Jan 15, 2020 6:42 pm
The response i’ve got from Keeley has been awesome. They have been quick to respond, very apologetic and are paying my postage and all repair costs. Can’t fault that.
J.
Shadoweclipse13
Post by Shadoweclipse13 » Wed Jan 15, 2020 9:15 pm
J.
That's fantastic. Everything I've ever seen of Robert Keeley is that he's a stand-up guy.
Futuron
Post by Futuron » Wed Jan 15, 2020 10:02 pm
Strange, everything I've seen is that he does audio electronics. Does he have a DVD of his routine?
8)
Shadoweclipse13
Post by Shadoweclipse13 » Wed Jan 15, 2020 10:16 pm
8)
Ha!
