Mini pedal hatred
- jorri
Re: Mini pedal hatred
The next size up is probably ideal. somewhere between that mooer size and boss size.
So, i took a mooer mini pedal off my board to use alone recording bass, and this thing was now rolling around everywhere, it has no weight to it and is top heavy, so meh.
I don't think by the end of it it save much space, because it ends up next to something with top jacks, or somehow has to be placed diagonally. Could work if i went and bought the exact cables i need but nah!
Then what happens to these Surface Mount components when it has a minor fault? it goes in the bin, no pedal, except for landfills; more waste. And all it needed was a new mini-pot. you cant play those tiny pots with your feet either.
- jorri
like a whole satanic tarot set of pedalssomanytoys wrote: ↑Fri Sep 27, 2019 12:53 pmWow. That actually looks kind of cool.
Kind of appropriate on something that resembles a serving tray. It almost looks like art or collectibles that should be glassed over to make it a shadowbox and hung on a wall.
Ahem - I mean scary, terrible stuff. Begone!
begone!
- min7b5
SMD circuits have always been be able to be repaired. The technical skill required is just higher. Most electronics are SMD, repairs just require different tools.jorri wrote: ↑Tue Oct 01, 2019 5:07 amThe next size up is probably ideal. somewhere between that mooer size and boss size.
I could start a thread on top mount jack hate though! Can't stand em.
- fuzzjunkie
Has anyone ever Velcro’d 1 or 2 to a guitar? Or put the guts from 1 and put it inside?
I probably wouldn’t do either myself.
Oh. It was a dick joke.somanytoys wrote: ↑Sun Sep 29, 2019 11:22 amHaha. Tell your friend that to me, they’re kind of a pain in the ass, although I will say that they don’t usually move - they typically stay right where you set them. They’re a little more difficult to move than the larger knobs. Smaller dial ratio, and I have to grip it with at least 2 fingers, and it might move a larger knob “on account of a accident” in the process.
I actually have a lot of pedals that use the tiny knobs. Half of the knobs on probably all of my full-sized VFE pedals are tiny by design (3 normal, 3 small). But for the added options that they allow for on the available room on the pedal’s face, it’s worth it.
I kind of hate trimpots even more, although there are those in many of those pedals as well, and others. Nice options, usually, but taking a pedal apart to move a pot or a switch is 4 times the pain in the ass.
Maybe 8.
And change.
Edit: I have to say - as much as I’m whining about all that, all of it still beats programming a bunch of parameters into something through an onboard interface menu.
I’ll do it with SPX 90s, but I think the Zoia is probably the only pedal that I’d do that with, if I got one.
(I obviously don’t have a lot of nice, powerful digital pedals...)
- somanytoys
Oh, sorry to ruin the joke.
That was my first impression, but then I wasn’t sure if you were seriously asking. For a friend.
So, then, uh, they’re only good for trimpots?
I got nothin’...
I got nothin’...
-David
- jorri
yes by someone else which costs money, and tends to not be worth it for cheap ass chinese clones.min7b5 wrote: ↑Tue Oct 01, 2019 5:54 amSMD circuits have always been be able to be repaired. The technical skill required is just higher. Most electronics are SMD, repairs just require different tools.jorri wrote: ↑Tue Oct 01, 2019 5:07 amThe next size up is probably ideal. somewhere between that mooer size and boss size.
I'm all good for desoldering a bypass switch or debugging components, even a blown cap, or dodgy connection, is all good.
Makes it also more difficult if everything is on the board, like jacks, knobs, switches, which is also somewhat flimsier that point-to-point wiring to a circuit board...then you have to check they fit the circuit board, not fry it when desoldering, and etc. is a pain in the ass. Unless i get someone else to do it.
But any dude with a solering iron can repair pedals with the traditional big components, it doesn't take much really, maybe some instruction or asking on a forum. tools are reasonably cheap if they use them to wire guitars, or diy pedals.
- jorri
'dude' being a gender-neutral form of course
- pj
I dig my Xotic SP compressor and Hotone Krush bit crusher. I also dig my Chase Bliss Faves which I use with my CB Mood. It's all good.
- Pacafeliz
- Mike S
The only one I own and have any use for is the MXR Phase 95.
If I could have all minis hooked up to a switcher I would be happy. For now my minis include: Xotic SP compressor, polytune mini, mooer elec-lady, mxr phase 95, Ibanez chorus mini, Ibanez analog delay mini. Want to add mxr carbon copy mini.
