Green Ringer Octave up and Down
Everyone needs a stompbox.
Mandeezee
Post by Mandeezee » Tue Jan 29, 2019 8:55 am
Does anyone know if there is a green ringer type pedal that also does an octave down? Ideally, I would like to be able to switch between the octave up and down with the option of combining both. Should I be looking at the POG?
fuzzjunkie
Re: Green Ringer Octave up and Down
Post by fuzzjunkie » Tue Jan 29, 2019 10:15 am
That’s really not how the Green Ringer circuitry works, at least not in the original. The MXR Blue Box on the other hand could possibly be modded to do that? Or perhaps have a Green Ringer circuit and a Blue Box style circuit in the same pedal and make them switchable? Electro Harmonix Octave Multi-Plex could sub for the Blue Box.
Or a nice and cheap and readily available option would be the t.c. electronic Sub-N-Up, which does somewhat what you want. It’s not switchable, but has control over how much octave up and down is in the signal. All of one or the other, or a mix of both, just no switching mid song.
The POG is more for a polyphonic solution you’re going to have more control than the Sub-N-Up, but it’s a much bigger pedal and does a lot more than up or down
The POG-2 has a preset switch, so you could possibly set it for either up or down and select between them, if that’s how it works. Other than that I think you’re looking at something like a Whammy or PitchFactor multi-effect pedal
Mandeezee
Post by Mandeezee » Tue Jan 29, 2019 11:26 am
Thanks for the info and the suggestions. I'll check them out.
Post by Pacafeliz » Wed Jan 30, 2019 2:20 am
My Dan Armstrong pedal has a green ringer in it, I love using it with a Boss OC-2 and a fuzz in front of it... :-*
Not helping but has to share it! :P
fuzzjunkie
Post by fuzzjunkie » Wed Jan 30, 2019 7:42 am
Yeah, it’s a cool sound. I think it’s better than the Oktavia style octave for analog circuits. You would probably like the Foxx Tone Machine, or a clone, it’s basically a green ringer and a big muff style fuzz (not exact circuit but similar result) in the same box.
Also found there is a POG mini, which does basically the same thing the Sub-N-Up does. Neither has the preset switch the POG-2 does though.
CorporateDisguise
Post by CorporateDisguise » Fri Feb 01, 2019 4:50 pm
The EQD BitCommander does both, but you can't footswitch between them seperatly, you would have to adjust your settings. While I think the POG range is great, its very different sounding compared to analog octavers. The POGs track all over the neck, and have a cleaner brighter sound. Analog generated octaves, both up and down will be much grittier and dirty sounding. They are also a bit warmer, and usually on track well above the 12th fret on the neck pickup. Below the twelth fret things get glitchy, which can be great, if your into it....
For clarities sake, I own both the POG2 and the Bitcommander.
I thnk the Foxrox octron does what your looking for and is all analog. A bit pricey, and I'm not sure if they still make them.
Mandeezee
Post by Mandeezee » Sat Feb 02, 2019 10:21 am
Wow. That FoxRox looks great. I just ordered a diy green ringer/fuzz before your post. Time to start saving and weighing the pro's and con's between the 2 and 3.
i love sharin foo
Post by i love sharin foo » Wed Feb 13, 2019 7:04 pm
The old Mu-Tron Octave Divider has a Green Ringer that is switchable on top of the Octave down function. For a true 'Ringer, that's where it's at. I've been using mine for damn near 20 years now. It is one pedal that I have never, ever considered selling.
That said, the Foxrox Octron2 is an AWESOME pedal as well. Similar tones but better tracking, smaller packaging, and lower price. Still regret selling mine.
"There are twists of time and space, of vision and reality, which only a dreamer can divine..."
