What are some good Trem pedals these days?
- MechaBulletBill
Re: What are some good Trem pedals these days?
Slight spam but... the BBE Tremor sounds eerliy close to the optical tremolo on a Fender amp, but with far greater range of speed and depth. No tap, but you can set two different speeds and switch between them (arguably better than tap). And cheap!
- shoule79
This 1000Xmarqueemoon wrote: ↑Sun Aug 12, 2018 11:25 pmThey should do a Waza PN-2 with tap tempo.
Lack of tap tempo (and the ridiculously small range of usable speed) are my only complaints about this pedal. Its still on my board, and not going anywhere though.
True, the speed range isn’t great. This and the size have kept if off of my main board.shoule79 wrote: ↑Mon Aug 13, 2018 4:44 pmThis 1000X
I don’t really care about tap tempo on a tremolo to be honest, but it’s a thing people seem to want.
I'm the same. My trem is almost always on, and I've never felt the need for tap tempo personally. I do think have a footswitch that alternates between two speeds would be cool as hell though. I'm not a huge fan of the placement of the footswitches, but that's why I've had this hankering for one of The Big Chill trems from Jam Pedals. That thing sounds really good.marqueemoon wrote: ↑Mon Aug 13, 2018 6:33 pmI don’t really care about tap tempo on a tremolo to be honest, but it’s a thing people seem to want.
- Zork
I've fancied a Stone Deaf Tremotron. It can be midi synced so if you play to a click or drum machine it shouldn't drift. And two tremolos that can be run together. Looks brilliant. Anyone used one?
- Unicorn Warrior
I really liked the Flint. While it did the optical thing well, it also had great Reverb. I think it was a matter of the unit not offering more versatility. It did have tap-tempo, the downside as that it required the external switch. Another downside to that is the lack of sub-division (to my knowledge).fuzzjunkie wrote: ↑Mon Aug 13, 2018 6:02 amWhat was too limiting about the Flint? I thought that was supposed to be top of the food chain as far as amp emulating tremolo pedals go? I only have the El Capistan from Strymon, but it seems to do what it says on the tin.
While everything that it did was great, my most use came from that optical trem feature. I had other reverbs holding the fort down. So basically, it was overkill and underkill if that makes sense.
- Sid Nitzerglobin
My friend had one, he was really hooked by the sync capabilities but they turned out not to work for him (I think he eventually got it synching but it didn't reset the clock/start on the one when engaging it unsynched IIRC). I played w/ it for about 10-15 minutes but it was pretty far down on my list of "tremolo pedals I want to use" from an ergonomics and sound perspective, YMMV of courseChip Korea wrote: ↑Tue Aug 14, 2018 2:35 pmI've fancied a Stone Deaf Tremotron. It can be midi synced so if you play to a click or drum machine it shouldn't drift. And two tremolos that can be run together. Looks brilliant. Anyone used one?
Of the trems I've had I could probably live pretty happily w/ just the Tap-a-whirl, the Flint, the Empress Trem, or the Monument, but I stay mostly more on the amp trem side of the sounds rather than the super wacky, stuttery, ducking stuff.
Gravitas is very cool, but has a pervasively grungy/funky quality soundwise that, while cool, kind of steps on it's ability to stand in for the amp trems super convincingly for me. If that sonic quality works for you (it really does for me, just not quite for when I want bias or photocoupler sounds which is a lot of the time) it's got options and sounds out the yin yang and all the midi/tap synch options for presets or tempo.
The Zvex Sonar is pretty great too, sounds like a pedal, but seems to work a bit better standing in for the amp sounds I'm looking for.
Last edited by Sid Nitzerglobin on Tue Aug 14, 2018 5:01 pm, edited 5 times in total.
- shoule79
Ditto on the tap tempo, but its nice to have.marqueemoon wrote: ↑Mon Aug 13, 2018 6:33 pmTrue, the speed range isn’t great. This and the size have kept if off of my main board.
- MechaBulletBill
cb semaphore in uk(no affiliation)
- Gavanti
When I replaced my flint, I tried a few trem pedals and eventually settled on a used Monument because of its flexibility. I’ve found it easy to work with and consistently good tonally, and it has tap tempo, expression, and momentary capability. About the only thing that tempts me now is a Rolo Twin Peaks.
Twin Peaks is a damn good sounding trem. I kinda want one too...Gavanti wrote: ↑Sat Aug 18, 2018 5:27 amWhen I replaced my flint, I tried a few trem pedals and eventually settled on a used Monument because of its flexibility. I’ve found it easy to work with and consistently good tonally, and it has tap tempo, expression, and momentary capability. About the only thing that tempts me now is a Rolo Twin Peaks.
- tele_pathic
I have the Stone Deaf Tremotron, and I love, LOVE it!!! Tap tempo, tons of tripppy wave patterns, expression pedal jack which can use a $50 EHX expression pedal to change rate, depth, or wave form. It can be subtle, it can be tripppy and it’s fantastic. All analog, so its super warm.
- Unicorn Warrior
tele_pathic wrote: ↑Sun Aug 19, 2018 11:09 amI have the Stone Deaf Tremotron, and I love, LOVE it!!! Tap tempo, tons of tripppy wave patterns, expression pedal jack which can use a $50 EHX expression pedal to change rate, depth, or wave form. It can be subtle, it can be tripppy and it’s fantastic. All analog, so its super warm.
I was wondering about that stone def pedal. I was going to purchase one once at vintage king in Nashville but I didn't because the employee there told me it wasn't subtle. I def need subtle..but I also def need whacky. So it can do subtle relatively easy?
- tele_pathic
Well, it’s got a depth knob to make it subtle. And it can get wacky. That’s what’s so cool about it. It’s an analog tremolo with a digital brain. SO its got the warmth of analog. The expression pedal, as I mentioned, can control depth, speed, and/or waveform. Think of Link Wray’s Rumble. The tremolo is on the whole time, right. But about 2/3 of the way through, he really increases the depth and maybe even the speed to some serious tremolo action. The expression pedal in can do exactly that sound. Not too many ANALOG trem pedals can do that. It’s not cheap, but it is hands down the best tremolo pedal I’ve ever heard and played. And add in tap tempo: not many trem pedals are this featured packed. Cool graphics to boot.Unicorn Warrior wrote: ↑Sun Aug 19, 2018 5:52 pmtele_pathic wrote: ↑Sun Aug 19, 2018 11:09 amI have the Stone Deaf Tremotron, and I love, LOVE it!!! Tap tempo, tons of tripppy wave patterns, expression pedal jack which can use a $50 EHX expression pedal to change rate, depth, or wave form. It can be subtle, it can be tripppy and it’s fantastic. All analog, so its super warm.
Now, it is a dual tremolo, meaning there are two tremolos in it. It’s hard to describe: hit YouTube for some good demos. To be honest, though, I never use the second tremolo. I just can’t get the timing right for the second one.
