Let's nerd out on clean boosts.
Everyone needs a stompbox.
marqueemoon
Post by marqueemoon » Tue May 29, 2018 6:31 pm
What do you all like for clean boosts? Maybe it's old age kicking in, but lately even transparentish overdrives seem like too much a lot of the time. If not for wanting a little more sustain and chaos at times I could probably be pretty happy with a clean boost as my only "drive" pedal.
Currently I'm using a Pigtronix Class A Boost (running at 12V) on one board and a Creation MK 4.23 on the other. I also have a ModKits DIY Piledriver I got for Christmas and built that I drag out sometimes.
Of the three the Pigtronix is the most neutral. It really just adds a touch of high end sizzle. The Creation has a ridiculous amount of boost on tap and seems to add a little more low mid girth. The Piledriver is somewhere in between.
Very curious about the Earthquaker Arrows, especially now that there's a V2 with silent switching. The One Control Granith Grey is another on the list of boosts I'd like to try.
mbene085
Re: Let's nerd out on clean boosts.
Post by mbene085 » Tue May 29, 2018 7:10 pm
I don't know whether this makes me cheap, or a hipster, or what, but I have an Artec DBT-1 Dual Clean Boost that has lived on my board for forever. I love it. It has two separate circuits that can be engaged, so you can have 4 total output levels (bypass, circuit 1, circuit 2, circuit 1+2). I've used it to drive amps, drive pedals, and even to equalize output between different guitars so that they could enter my pedalboard with the same gain when swapping guitars at a gig.
Looking it up now, I've found mention that it's apparently a clone of a zvex pedal. Didn't know anything about that when I bought it 10-ish years ago, but looking at it now, the control layout is just like the super duper 2-in-1, except 1/5th the price.
Anyway, if you want a versatile two-channel boost, it's tryye bypass and won't break the bank. The ones I see online are even visually identical to mine so I don't think they've changed anything about it in the last decade.
marqueemoon
Post by marqueemoon » Tue May 29, 2018 7:51 pm
Huh. How much coloration is there when running both?
Shadoweclipse13
Post by Shadoweclipse13 » Tue May 29, 2018 8:49 pm
I mostly use my Catalinbread Naga Viper as a clean boost (and for every other type of boost). I agree that I like a little extra sizzle on the cleans, just enough. I've also really been looking at the EQD Westwood to use as a boost/low gain overdrive.
My favorite clean tones are never pristine: Mark Engles with his Dredg stuff, and the guys from As Cities Burn, all have amazing clean tones, which are just a tiny bit driven.
stevejamsecono
Post by stevejamsecono » Wed May 30, 2018 10:53 am
I've used the SD Pickup Booster, Super Duper 2 in 1, and the MXR Micro Amp. All of these things are pretty great. I'd been pretty curious about trying a Rangemaster-esque circuit like the Naga Viper for something a little different.
OSG Resident Yamaha Fanboy
SY6655321
Post by SY6655321 » Wed May 30, 2018 11:36 am
i use one of these. it sounds great, and only 1 knob!!!
marqueemoon
Post by marqueemoon » Wed May 30, 2018 2:08 pm
I’d also like to try a Micro Amp.
Yeah, my “clean” sound isn’t very clean these days.
hardtail01
Post by hardtail01 » Wed May 30, 2018 5:13 pm
I've got a SD Pickup Booster that i like a lot. They are inexpensive used, and they work well. I don't have any desire to try other clean boosts as this one sounds good to me.
NoiseNoiseNoise
Location: Hertfordshire, England, Britain, UK, Europe, Earth, Outer Eastern Rim, Western Spiral Arm.
Post by NoiseNoiseNoise » Thu May 31, 2018 5:34 am
What, no mention of the ORIGINAL "Clean Boost", the EHX LBP? Why not??? It's only been around for nearly 50 years!!! :)
marqueemoon
Post by marqueemoon » Sun Jun 03, 2018 10:40 pm
Brought a different guitar to practice with a hotter pickup tonight. Turns out the clean boost didn't do so much as the pickup was already hitting the amp so hard. Overdrive worked better as it brought out some mids, giving the sense of a volume bump. I think I'm going to try backing the pickup down to see if I can get a little clean headroom back.
loveinathens
Post by loveinathens » Sun Jun 03, 2018 11:07 pm
I'm currently using an EQD Black Eye clone to help me with my lower output guitars and I love it.
pj
Post by pj » Tue Jun 12, 2018 12:34 am
I had a Zvex S.H.O. that I used with a Trademark 60 solid state amp. It was a wonderful combination.
MechaBulletBill
Post by MechaBulletBill » Tue Jun 12, 2018 5:20 am
I like the low gain side of the Broadcast as a clean boost to push an amp. The low-end cut is really useful.
Jestapali
Post by Jestapali » Wed Jun 13, 2018 3:03 am
TC Electronic Spark boost: Fat, Clean, Mid modes. Tweekable tone. Great and versatile pedal.
mbene085
Post by mbene085 » Wed Jun 13, 2018 3:20 am
You know, I'll have to fire it up again to check. I typically used one side or the other, to match the input gain going into my compressor for a couple of different guitars when switching between them in a live set. I wasn't using it to really drive a pedal or amp hard, so I never needed more than one side at a time.
