Looking for info on an extremely rare tube amp
Make it loud here.
øøøøøøø
Re: Looking for info on an extremely rare tube amp
Post by øøøøøøø » Wed May 22, 2013 5:06 am
Ibanez666 wrote:Ok, thanks for the Info! One of the transformers says "Bayern" I believe
A-ha... Bayern (Bavaria) is a state in Germany. The transformers in the amp have a distinct "GDR" type of look to them. Bavaria was located in West Germany, technically, but it bordered the communist GDR and some villages were actually split between the two countries at the time.
The amp has a decidedly UN-western look to it in terms of the meticulousness of its construction... however the Philips caps are definitely a Western thing, but the transformers and the green look to be from the East.
Interesting thing... probably indeed of Bavarian or Eastern European origin.
Ibanez666
Post by Ibanez666 » Wed May 22, 2013 5:29 am
So how do you think adding an extra volume control would work out? I mean so you can set preamp vol and power amp vol to get overdrive at lower volumes? Is that an easy thing to do? Can I use the two tremolo pots for that?
øøøøøøø
Post by øøøøøøø » Wed May 22, 2013 5:35 am
I wouldn't mod that amp for a master volume. if you need a master volume amp, sell that one and buy one.
It's rare and unique enough that i think it should be left original.
Jaguar018
Post by Jaguar018 » Wed May 22, 2013 6:41 am
øøøøøøø wrote:I wouldn't mod that amp for a master volume. if you need a master volume amp, sell that one and buy one.
øøøøøøø is right-- adding a master volume to an old amp is generally frowned upon since it is usually a non-reversible modification. Most amp techs with scruples won't consider modding a cool, rare old amp unless the mod can be reversed.
If you really want to get that amp to overdrive at lower volumes I'd get an OD pedal or an attenuator.
Ibanez666
Post by Ibanez666 » Wed May 22, 2013 9:25 am
Hmmmm...sound like wise words :)
Ibanez666
Post by Ibanez666 » Thu May 23, 2013 11:08 pm
The amp takes pedals very well.. It has a very clean and neutral sound that really does justice to the guitar you're using. It even made my old BOSS DS-1 sound good!
OffYourFace
Post by OffYourFace » Thu May 23, 2013 11:26 pm
it's a very cool looking amp! wish i could hear it in person..
synth tech at www.rosensound.com
Post by 46346 » Fri May 24, 2013 2:08 am
i dig the more spacious layout! from the looks of it,
i'm guessing the sound would be Fender/Hi-Fi
very cool!
shouldn't be much trouble getting the tremolo and reverb going.
rather than a master volume mod, try it with some less efficient alnico speakers. but don't melt them either... you're looking at 60-80 watts output!!
Dream Apes, ACME, Malcolm Mooney, Cat Museum, Cooling Time
Ibanez666
Post by Ibanez666 » Fri May 24, 2013 7:09 am
46346 wrote:i dig the more spacious layout! from the looks of it,
very cool!
Youre right about the sound. And it can get pretty loud.. its a very neutral sounding amp. Wit eq you can go from very thin to super warm. This amp has some bass!
Steadyriot.
Post by Steadyriot. » Sun May 26, 2013 8:53 pm
Seeing that head, I'd look into Dynacord amps, also German made I believe and to me they share a same kind of 'Look'.
Ibanez666
Post by Ibanez666 » Tue May 28, 2013 4:32 am
Steadyriot. wrote:Seeing that head, I'd look into Dynacord amps, also German made I believe and to me they share a same kind of 'Look'.
I'l try that out as well :)
doctorock78
Post by doctorock78 » Wed May 29, 2013 5:39 pm
Sound clips maybe later?? :) So intriguing that amp
Ibanez666
Post by Ibanez666 » Thu May 30, 2013 4:30 am
Hmm I'll try to make some dunno when I have the time thouhg
ECHO
Post by ECHO » Thu Jun 06, 2013 7:55 pm
now that is cool. interested to see what info can be rounded up.
Owner/Builder,
Wattson Classic Electronics
wattson-fx.com
citizen_insane
Post by citizen_insane » Fri Jun 07, 2013 8:00 am
doctorock78 wrote:Sound clips maybe later?? So intriguing that amp
I second this, I'd love to hear what it sounds like!
