Alternatives to my HRDx/Another Fender Combo. Help!
- stevejamsecono
Hey All,
I've had a Fender HRDlx for almost two years now. I'm fairly fond of the clean sound and reverb that I can get from it (at the very least the Fender sound period), and would like to stick with this kind of sound, however I've found that the bass response on it is pretty flabby, and just in general the sound is flatter than it could be. I play mostly small to medium sized clubs right now, so a Twin is too loud for my needs, but I wouldn't be opposed to something with 2 12 inch speakers for added sound projection. My goal would be something between 30-50watts max (although I've heard the 22w Deluxe Reverb isn't too bad) and I could probably get a nice Avatar 2x12 too if I wanted. I get all my distortion/wallo'sound/effects from pedals, so an overdrive channel on the amp is not neccessary (althought wouldn't be bad). Any ideas kids?
-Steve
-Steve
It's so hard to understand
Resident Yamaha Fanboy
COYS
COYS
- TheMilford
Re: Alternatives to my HRDx/Another Fender Combo. Help!
Sounds like you need a Pro Reverb.
around 35-40 watts... you might be able to find a silver faced era model for less than $1000
if you just want a head you could get a Bandmaster Reverb or a regular Bandmaster and use an EH Holy Grail for reverb.
http://www.tronographic.com/
- mezcalhead
- Admin
All good suggestions. Non-reverb Bandmasters are usually pretty cheap I think .. I'm often surprised at just how cheap the non-reverb blackface heads are in general for what they are, and the early silverfaces are even more reasonable and have basically the same circuit.
I'm not too familiar with the HRDlx .. is it a 2x10"? If you like the overall sound of the amp you might find that new speakers do the job .. maybe with a new baffle you could get a pair of 12"s into it .. probably the most economical solution and you can keep the old speakers and baffle in case you ever want to sell it.
Plus, if that doesn't quite work you can get an old (Bandmaster?) head, sell the HRDlx with original speakers and put the 2x12" speakers in a cab.
- stevejamsecono
HRDlx is 1x12, I'm not sure what type of speaker the stock one is. It's 40watts, 1 and two thirds channels. (1, some kind of solid state drive circuit, and then another gain stage added after that I believe.)
Pro Reverb eh? hmmm
I had thought about heads, I just would like to be able to bring a smaller combo to practices, and then amp it up with a cab for shows. I could be convinced however..
Pro Reverb eh? hmmm
COYS
COYS
- Jay
- Admin
You'd be suprised how loud the blackface deluxe reverb is... and they can get a fairly good twin-like sound at less volume. That's what I would go for if I were in your shoes. I've had two pro reverbs that for one reason or another never worked for me. They were always a little dirty and not in a pleasing manner. Those were both silverface however, I imagine one that's been cleaned up and properly put back to black specs wouls be better.
- TheMilford
The silver Pros can sound a little bright.
I repaired a friends Blackfaced Pro a few monthes ago and it was AMAZING?
I thought silverface fenders sound cleaner in general, a bit too clean even. Did you have the master volume on 10?Jay wrote: You'd be suprised how loud the blackface deluxe reverb is... and they can get a fairly good twin-like sound at less volume. That's what I would go for if I were in your shoes. I've had two pro reverbs that for one reason or another never worked for me. They were always a little dirty and not in a pleasing manner. Those were both silverface however, I imagine one that's been cleaned up and properly put back to black specs wouls be better.
what's up with the questionmark?TheMilford wrote: The silver Pros can sound a little bright.
- TheMilford
Ooops I meant:Sauerkraut wrote:what's up with the questionmark?TheMilford wrote: The silver Pros can sound a little bright.
I've been thinking about replacing my silverface twin with a silverface pro reverb as it's much too loud, but pro reverb's are quite expensive soTheMilford wrote:Ooops I meant:Sauerkraut wrote:what's up with the questionmark?TheMilford wrote: The silver Pros can sound a little bright.
