what is this input/output jack for?
I found a hole in my amp!!!
- zhivago
- TheMilford
Re: I found a hole in my amp!!!
Bias pot or a Bias point?
where does it go, can photo the inside?
http://www.tronographic.com/
- enormous
It shouldn't be a hole, it's the potentiometer you turn to adjust the bias. You need to use a flat-head screwdriver to turn the shaft, I assume that they didn't use the normal longer shaft ( ) so that you wouldn't bump it and screw up the bias.
- Mad-Mike
I'll go with these guys on it being a Bias tuner pot.....
But when I first saw it I thought it was some sort of strange phono Jack, like for an external cab, that was added on
It's Me
- zhivago
ahhhh...I see...hehe...cool...well, I dunno how to bias amps, so I guess I won't be touching that one
thanks for the replies!!
