Help for repairing a friend's amp
- Superfuzz
As the title suggests, here at home I have an amp (marshall Valvestate model 8080) of a friend of mine for repair. Since he knows I like messing with that thing of problems he has brought it to me and so now I'm giving it a look..
The basic problem is that no sounds comes out (if cranked totally to the max you can hear a very very low signal coming out of the speakers, something impercettible).
-I've checked the pre-amp stage running it into another amp from the fx out and it works fine.(so the problem should be in the output stage)
-Once opened the amp for ispection I've found two big caps that are litteraly desoldered, one of these looked damaged so I've changed them both. Anyway the problem isn't solved yet, still no sound.
- With a better inspection of the bottom of the pcb I've found that just under some big resistors (I presume they are for the output stage) there's an orange halo, something like when you heat PCBs and the protective coat burns away, the whole area under them looks browned too..the resistors look good anyway, they doesn't show any damage, I could change them but maybe I won't solve the problem..
I've already tested them with a multimeter, it says 0.00 when I connect the two plugs..but since I'm new about checking resistors with a mutlimeter I'm not sure if I'm right..I've tried measuring small .25W resistors and I can measure them all, but this big ones always say 0.00 to me..
BTW
My question is: Is it safe to check all the circuit with the meter while the amp is under power as I usually do when I get problems with stompboxes?
BTW
- fuzzking
Re: Help for repairing a friend's amp
Sorry I can't be of further help on the issue - but I would definitely NOT do that unless I knew EXACTLY what I was doing.
Nobody exists on purpose.
- Superfuzz
Well, I know the better solution will be a tech, but before going in that way I think I could give it a try if we're talking about replacing some burned resistors..right?FUZZ_KING wrote: Sorry I can't be of further help on the issue - but I would definitely NOT do that unless I knew EXACTLY what I was doing.
- fuzzking
Man, I just don't want you to get fried (real concern here) - maybe wait until the guys with amp knowledge chime in?
Anyone?
M
Anyone?
M
- Felix
This is the only part where I'd suggest some caution. I would think it's far more risky to prod around a powered up amp than a guitar pedal.Superfuzz wrote:
Don't toast yourself man. ehhh...
"That's just Dorian"
- Dr. Cox
- Dr. Cox
- Jay
- Admin
You don't need power to check the resistors. If they say zero then they are probably zero ohms or no resistance (that or infinite resistance) meaning they are open. I would replace them. You only need power on an amp when your probing for voltages and then must be VERY careful obviously.
- mezcalhead
- Admin
Jay's right, you shouldn't need voltage to check the resistors.
Seriously, if you're not clear what you're doing you can kill yourself easily enough.
PLEASE DON'T DO THIS.Superfuzz wrote: My question is: Is it safe to check all the circuit with the meter while the amp is under power as I usually do when I get problems with stompboxes?
- pullover
NEVER CHECK RESISTANCE WITH POWER CONNECTED!!!!! You can burn up your meter and possibly yourself. Some resistors need to be removed from the board to check them due to the circuit designs. Just remove one side from the board and then put the meter across the resistor. Also make sure that there is no power in the caps before sticking your hand in there. Obviously you have to check voltage and current with power applied.
Don't worry too much about electrocuting yourself, IF YOU KNOW WHAT YOU'RE DOING. When you have power turned on use a gator clip on the negative lead and clip it to ground. Then take your left hand (or whichever hand isn't your dominant hand) and stick it behind your back. I used to hold onto my belt until I got used to it, that way if you do get electrocuted, the power won't go directly through your heart. Usually when resistors burn up, they show as open though.
- Superfuzz
Hey guys, I'm calling you from paradise, oh well, from the hell( )..so I've checked the amp and I get fried..
Ok, stupid joke , I was suspecting that going in that way is dangerous..but just to be sure..
BTW, when I get the time I'll try do desolder one leg of the resistor and I'll try to check it again, if it's 0.00 again..I'll replace it for sure..
- pullover
Well, it's dangerous, but as long as you work on it smartly, there is no reason to fear. Just make sure that all the caps are properly dissipated before sticking your hands inside, and use the one hand rule when energized.
- Superfuzz
here's a pic of the suspected resistors..
- pullover
well, it definitely looks bad, but I have seen worse that still function. Some resistors, get real hot, and they are designed to take some punishment.
- Superfuzz
So they might be fine?pullover wrote: well, it definitely looks bad, but I have seen worse that still function. Some resistors, get real hot, and they are designed to take some punishment.
- pullover
Yup, MIGHT be, Only way to know for sure is to pull up one side of the resistor and measure across it. It's not uncommon to see heat stress around those power resistors.Superfuzz wrote: So they might be fine?
- fuzzking
Glad to see you're still there, man!
