HRD > Bassman project! SUCCESS!!
Make it loud here.
JSett
Re: Another old friend...
Post by JSett » Wed Apr 24, 2024 7:27 am
Dr Tony Balls wrote:
Wed Apr 24, 2024 7:25 am
Hard to say. Those F&Ts are 38mm long, and the board you bought is 45 with the turrets set in a bit....it'll be a tight fit for sure but you may be able to elevate the caps above the turrets if there's not enough clearance.
I did think that was what was probably gonna have to happen.
Or there's this one that's the same sort of style you usually use with the double tabs.
*EDIT: actually, screw it. I've ordered one of those instead. It's a little cheaper and looks to be a bit more spacious. Not a lot, but an extra 10mm would be nice and I like to silicone down the big caps
JSett
Post by JSett » Wed Apr 24, 2024 8:13 am
I do have a few of these I can use too, it it makes laying things out more convenient...
I was going to use one near the PT to do the centre tap, and maybe ground the resistor from the bias pot. But I have at least 1 spare
Dr Tony Balls
Post by Dr Tony Balls » Wed Apr 24, 2024 8:24 am
This PT has no center (centre) tap, the reference to ground will be created with a bridge rectifier. So you wont need a terminal strip there. Could to know that you have them, though, and can always use them for caps that dont fit, screen grids, etc. This will all click into place a bit when I get a layout worked up.
Instagram: thetonyballs
JSett
Post by JSett » Wed Apr 24, 2024 8:30 am
Ahh, okay. I knew there was no centre (center) tap and assumed I'd have to do a virtual one with two 100r to ground like I did on my amp build back in 2022. Is there a bias tap on the PT or is that done with circuit trickery too? I couldn't see one but the cables are messy AF in there :D
I just looked and I have 1x 5 way (1 to ground) and 3x 3 way (1 to ground) of those mini terminal strips to play with. One will be nice on the 1k5 resistors coming from the power tube pins 5 before they go to the master volume for extra stability. I can do that myself though, no need to include on a drawing.
Dr Tony Balls
Post by Dr Tony Balls » Wed Apr 24, 2024 9:10 am
Easy part is done. To note:
1) no center tap on the PT secondary. ground reference is achieved through bridge rectifier.
2) no center tap on the PT filament secondary. ground reference is achieved through R30 & R31.
3) brown utility tap used for bias voltage.
4) master volume is dual gang.
JSett
Post by JSett » Wed Apr 24, 2024 9:55 am
Cheers Tony, that is great. I'm trying to read it and check what I know vs my parts list.
Is C7 supposed to be 0.001uF or should it be 0.01uF?
Dr Tony Balls
Post by Dr Tony Balls » Wed Apr 24, 2024 9:56 am
You're correct, that should be 0.01uF
Here's a rev 2.0:
Last edited by Dr Tony Balls on Wed Apr 24, 2024 10:00 am, edited 1 time in total.
JSett
Post by JSett » Wed Apr 24, 2024 10:00 am
Whoop! I'm learning :D :D
Dr Tony Balls
Post by Dr Tony Balls » Wed Apr 24, 2024 10:01 am
Oh also all resistors are 1/2W unless noted.
JSett
Post by JSett » Wed Apr 24, 2024 10:24 am
Yeah, I gathered as much. I've got a lot here but all 1w so I've ordered what I need in the same wattage for now so they're mostly the same size visually.
Knowing what I know of schematics (very little) it is still starting to make sense. I can see each section now and know what it does - to a point. Translating it into a 3D layout and subsequent building is where I fall short :D
JSett
Post by JSett » Wed Apr 24, 2024 10:27 am
Here's my high tech parts list :D ...
I went with 1N5408 1000v Rectifiers
Dr Tony Balls
Post by Dr Tony Balls » Wed Apr 24, 2024 10:29 am
1w is FINE, just maybe a little bigger.
You're gonna need FIVE diodes. Make em 1N5408s.
JSett
Post by JSett » Wed Apr 24, 2024 10:30 am
That's handy, I just ordered 5 more - and 1N5408 as well. Pretty sure I have some in the drawer somewhere too but they're small and I can't see them
I only just spotted the one in the bias circuit too. Sneaky little begger
JSett
Re: Another old friend... Now a HRD > Bassman project!
Post by JSett » Wed Apr 24, 2024 11:39 am
For anyone else following, I've made a parts list:
The 'Ordered From' is obviously for my reference. You can buy from wherever.
OffYourFace
Post by OffYourFace » Wed Apr 24, 2024 12:20 pm
Damn now I want to do a custom Hotrod amp
