Amp loudness?
- Larsongs
Re: Amp loudness?
My brother is coming over Saturday to play & maybe record.. While he’s here I’ll let him hear what I’m hearing & let you know..
I’m no Electronics Guru or any kind of Guru for that matter.. These are 2 totally different Amps & most likely it isn’t simple.. Unlike me.
I’ve come away with a lot more respect for 65 DRRI’s than I had before…
By tweaking the Volume on the Twin I can get them balanced.. Maybe it’s just the way it is..
I get curious & try to figure out why..
I appreciate any recommendations for reasonably priced Tubes that will help best replicate what was in vintage 60’s Twins..
Thank you all for all the information you provided.. I found it very helpful..
- Larsongs
Re: Amp loudness?
We forgot Coachella is going on this weekend.. I live about a mile away.. The Traffic is crazy so we rescheduled for the middle of the week.
I record Stereo using the Twin set at 25 Watts & my 65 DRRI thru my Stereo Keeley ADT Pedal with equal volume levels going to Channel 3 & 4 (L&R) on my Focusrite Interface I have to turn the Twin’s volume to 8 to be the same as my DRRI with Volume set at 5…
Maybe it has more to do with the Science of Electronics?
- sessylU
Re: Amp loudness?
Hmm, a lot going on here.
First step would be set the amps up so that they are as loud as each other, then see which one is louder.
a total idiot jackass
- Dr Tony Balls
Re: Amp loudness?
Again...microphones, speakers, pot taper, etc all have influence over this.Larsongs wrote: ↑Sat Apr 20, 2024 11:15 amI record Stereo using the Twin set at 25 Watts & my 65 DRRI thru my Stereo Keeley ADT Pedal with equal volume levels going to Channel 3 & 4 (L&R) on my Focusrite Interface I have to turn the Twin’s volume to 8 to be the same as my DRRI with Volume set at 5…
What we're explaining here *is* the science of electronics.
Instagram: thetonyballs
- Larsongs
Re: Amp loudness?
Yes I know.. There’s a lot I can learn for sure & you all are a big help.. ThanksDr Tony Balls wrote: ↑Mon Apr 22, 2024 5:54 amAgain...microphones, speakers, pot taper, etc all have influence over this.Larsongs wrote: ↑Sat Apr 20, 2024 11:15 amI record Stereo using the Twin set at 25 Watts & my 65 DRRI thru my Stereo Keeley ADT Pedal with equal volume levels going to Channel 3 & 4 (L&R) on my Focusrite Interface I have to turn the Twin’s volume to 8 to be the same as my DRRI with Volume set at 5…
- crazyzeke
Re: Amp loudness?
Might not be related but that's a lot of hours... have you ever had the amp fully recapped?
- 46346
Re: Amp loudness?
wow - i was unaware that TAD's 6L6WGC-STR is considered a remake of my beloved GE 6L6GC's.OffYourFace wrote: ↑Mon Apr 15, 2024 11:39 pmI like these but they’re expensive. They’re a bit overpriced but I think they sound better than JJs even at normal clean levels.
TAD
and some of the components look quite similar indeed. i still have a fair stash of GE's, but if these are actually
close to that sound, they'd be worth the price of admission, especially for an amateur tech like me who worries about blowing up a precious tube while experimenting...
i run the GE's in my Blonde Bassman as well as a 1968 Super Reverb, and they became my all-time favorite 6L6 type for Fenders. they've got a warm, harmonic throb in the low end, that isn't too loose, and a sweet articulation. like you say - even when run clean.
- OffYourFace
Re: Amp loudness?
yeah i really like them. I have a pair in my '67 Bassman and I haven't changed them in like 10 years. But i don't use that amp very often. Too loud.46346 wrote: ↑Sat Apr 27, 2024 11:55 pmwow - i was unaware that TAD's 6L6WGC-STR is considered a remake of my beloved GE 6L6GC's.OffYourFace wrote: ↑Mon Apr 15, 2024 11:39 pmI like these but they’re expensive. They’re a bit overpriced but I think they sound better than JJs even at normal clean levels.
TAD
- Larsongs
Re: Amp loudness?
We’ve had 3 weeks of Coachella fest & Stage Coach.. The traffic is crazy. So my brother & I haven’t got together as yet & Sessions with friends have been postponed..
I’ll be talking to my Bro today & make a plan for our next Session.. We’ll do a test of the Amps loudness..
Do you think the TAD’s you mention above a good sound for an early 2000’s Fender 100 Watt Pro Tube Twin?
