Incoming TS-50B schematic / PT advice requested...
Make it loud here.
JSett
Post by JSett » Mon Mar 11, 2024 5:22 am
I finally found a TS-50B at the right price to replace the one I stupidly sold 8 years ago. Now, back then I didn't mess with the insides of amps too much but managed a 110>230v swap. Fast forward to now and I'm going to need to do it again... but I don't know what transformer I'll need.
Google has been no help at all, but there is a schematic:
BASS GO BRRRRP
Can someone with a better understanding take a look and maybe point me in the direction of a suitable replacement? Last time I used a toroidial but happy to use a traditional style as well.
Dr Tony Balls
Re: Incoming TS-50B schematic / PT advice requested...
Post by Dr Tony Balls » Mon Mar 11, 2024 6:55 am
That's a split-supply bridge rectifier producing +/- 35VDC. My calculation chops are rusty/confused on this sort of thing so its hard to back out the correct AC input voltage but given that the schematic says 200V I think that makes sense. It would be listed as 200V CT or maybe 100-0-100 V because it has a center tap.
Instagram: thetonyballs
JSett
Post by JSett » Mon Mar 11, 2024 7:19 am
Yeah, I traced the schematic to see the 200v and 35v parts but wanted to be sure.
Now to try and actually find one. Gonna be a fun evening sifting through spec sheets :D
JSett
Post by JSett » Mon Mar 11, 2024 8:18 am
Fucking hell, finding one is nigh impossible. I might have to get a custom wound one, annoyingly
Maybe I'll just run a step-down :D
Dr Tony Balls
Post by Dr Tony Balls » Mon Mar 11, 2024 9:21 am
The step down will be WAY easier.
JSett
Post by JSett » Mon Mar 11, 2024 9:33 am
I know. I hate having excess shit in-line though, and step downs - even the nice expensive one I bought - tend to make noise which I find distasteful.
I'll still keep an eye out. Maybe I can pick up a donor amp that's already 230v and swap them out.
ryland
Post by ryland » Mon Mar 11, 2024 9:37 am
I think that the 200V 8A reference is to specify the rectifier diodes. Given that this is a purely solid state amp by the looks of it, generating a split rail 35 VDC supply using two 16V Zener diodes, I would suspect that the power transformer is likely a roughly 40 VAC output.
It looks like this is the same voltage that the clone works on: Rusty Box
JSett
Post by JSett » Mon Mar 11, 2024 9:58 am
This actually makes a lot more sense to me than the 200v. I have a Rusty Box actually, for a while I had one of those, a TS50 combo, TS50b head AND TS70B combo. Only the pedal remains until this arrives.
40VAC is going to be much easier to find
ryland
Post by ryland » Mon Mar 11, 2024 10:12 am
I'm glad there's some use for my mostly unused EE degree...
JSett
Post by JSett » Mon Mar 11, 2024 10:20 am
Hah! I wish I'd studied it!
This looks like it might do the trick...
https://cpc.farnell.com/multicomp/mcta2 ... dp/FF01572
Thoughts? It doesn't appear to have a center tap on second look. Gah! Obstacles
Dr Tony Balls
Post by Dr Tony Balls » Mon Mar 11, 2024 10:31 am
The Rusty box works on 30V but remember that's just the preamp from a TS-50B. The 30V is functionally the same as the +/- 15V supply. The Rusty has no +/- 35V supply.
ryland
Post by ryland » Mon Mar 11, 2024 11:00 am
Ah, ok, I took the internet at face value :fp:
You're making me do the math, which is a good thing. For one rail (we'll double this at the end to get the full Ac voltage), we know we want 35 VDC,
adding in two diode drops at a nominal 0.6 VDC each gives us 35+1.2 = 36.2 VDC,
Dividing this by the square root of two to get the AC volatage from the transformer gives us 36.2/1.44 = 25.1 VAC.
Doubling this to get the full AC volage yields a 50 VAC transformer output rather than my earlier guess of 40 VAC.
I don't know what the transformer mounting of the TS-50B looks like, you may want to try to find something in a similar form factor when you lay eyes on it...so I don't know how a toroidal will fit...
Dr Tony Balls
Post by Dr Tony Balls » Mon Mar 11, 2024 12:03 pm
Looking at this again, the rectifier looks essentially like two full wave rectifiers, with one being for the positive rail and one for the negative. Doing the math hre i'm coming up with a 25-0-25 transformer giving you +/- 34.25 V. So I think I concur with the 50V assessment.
Post by s_mcsleazy » Mon Mar 11, 2024 12:08 pm
legally, the only way to test one of these amps is with a travis bean bass OR a peavey t40...... those the rules.
JSett
Post by JSett » Mon Mar 11, 2024 12:12 pm
I won't comment on the maths as I don't understand it, but I can comment on this. The last one I had I just drilled the chassis for the mount and stuck it in there routing the wires through one of the old mount holes. The transformer came loose with the amp.
