anyone know who in the UK rebuilds speakers?
- s_mcsleazy
it's coming time to rebuild my fanes and my traynor speaker. who does this stuff? most of what i get on google is for hifi's.
- MechaBulletBill
Re: anyone know who in the UK rebuilds speakers?
i've spoken with recones.com, there's also wembley loudspeaker. anyone with the correct replacement cones etc should be able to do the fanes.
what's the traynor driver? if it's a marsland then general consensus is that anything else is an improvement. i like the jensen neodymium in my traynor a lot! i'd put them in everything if they were cheaper.
- UlricvonCatalyst
I have it from a reputable source that a steady build-up of layers of tissue paper with watered-down PVA is as good as a recone, if you want to make do and mend.
- s_mcsleazy
i'm not super fussed about the traynor since it currently has a fane in it. it doesn't suit the amp but i kinda just want my other 2 fanes rebuilt more. i might look into the jensen just as a drop in replacement.MechaBulletBill wrote: ↑Thu Dec 07, 2023 3:33 pmi've spoken with recones.com, there's also wembley loudspeaker. anyone with the correct replacement cones etc should be able to do the fanes.
i did that with an old celestion rocket and it worked but it wasn't great.UlricvonCatalyst wrote: ↑Fri Dec 08, 2023 5:24 amI have it from a reputable source that a steady build-up of layers of tissue paper with watered-down PVA is as good as a recone, if you want to make do and mend.
