Hello--
The cheapo footswitch that came with my DRRI crapped out almost immediately after I bought it (used). One of the switches just stopped clicking.
As cheaply made as it feels, these things sell for almost $50, so I don't want to buy a new one. I'll see how much to repair this one, but before I invest anything I'm wondering:
Is there are sturdier/better replacement out there? Just has to turn on/off Reverb and Tremelo.
Thanks!
Better 2-button footswitch for Fender amps?
- dffny
- oid
Re: Better 2-button footswitch for Fender amps?
A new switch is $5 to $10, five minutes labor, if you can solder you can fix it. If you can not solder you can still fix it, it will just take ten minutes instead of five.
- brucer
Yup. Cheap and easy to fix.
Also cheap and easy to build your own in a sturdy little enclosure. That's what I did: http://www.madbeanpedals.com/forum/inde ... ic=23435.0
But ... there are also some nice aftermarket options if that's more your thing: https://www.vein-tap.com/product/dual-l ... ootswitch/
Blank.
- _nash
I build them with LEDs and detachable cables. Much higher quality. I can help out if you need anything. Might even have a switch laying around.
