Fender Vaporizer Amp
Make it loud here.
higgsblossom
Re: Fender Vaporizer Amp
Post by higgsblossom » Mon Jan 29, 2018 10:18 am
I bought one in Surf Green, and the day it arrived bought another one in Slate Blue. A Fender tube amp for 180€...
It is a very nice amp.
I‘m thinking about getting a better reverb tank. Any suggestions?
selectomatic
Post by selectomatic » Mon Jan 29, 2018 7:33 pm
I'm not sure if you're looking for a new spring pan to go into the Vaporizer or a separate reverb unit you can plug into it. If it's the latter, you may want to consider the Surfy Bear FET Reverb, which replicates Fender's original 6g15 circuit but without vacuum tubes. It's a DIY kit, which greatly reduces cost, and you add your own enclosure and pan. If you don't mind a bit of soldering, it could be the answer.
https://www.surfyindustries.com/surfybe ... -faceplate
higgsblossom
Post by higgsblossom » Tue Jan 30, 2018 12:27 am
That's what I was looking for, thank you very much!
