Bass amp for practice/at-home recording
Make it loud here.
Post by Stereordinary » Wed May 10, 2017 6:00 pm
A friend and I are both in the same situation. We need bass amps that are good quality (in the sense that they will last a while), pretty inexpensive, and good for practice and maybe some home recording. Any recommendations?
mackerelmint
Re: Bass amp for practice/at-home recording
Post by mackerelmint » Wed May 10, 2017 7:23 pm
Get an old Fender sidekick. Cheap, reliable, sound good.
thisisnickpaige
Post by thisisnickpaige » Wed May 17, 2017 6:30 am
Not the smallest thing ever, but the Ampeg BA-115 is a killer amp, cheap price, has a style knob for varying voices, doesn't weigh as much as you'd think, and it has an XLR out and headphone out. This is the amp i used for about a decade until i switched to the Sansamp Bass Driver exclusively. I had the older tilt back model from the 2000's. It was $300 or something, maybe less.
Also, the Fender Rumble amps are a pretty great choice. I used an earlier model a while back, but i haven't tried the new ones.
Jesus
honeyiscool
Post by honeyiscool » Fri May 19, 2017 2:24 pm
Rumble 100? Not my favorite DI in the world, but it certainly gets the job done in every regard.
sears
Post by sears » Sat May 20, 2017 6:49 am
thisisnickpaige wrote:Not the smallest thing ever, but the Ampeg BA-115 is a killer amp, cheap price, has a style knob for varying voices, doesn't weigh as much as you'd think, and it has an XLR out and headphone out. This is the amp i used for about a decade until i switched to the Sansamp Bass Driver exclusively. I had the older tilt back model from the 2000's. It was $300 or something, maybe less.
+1. The new fender combos sound good.
Depending on home practice needs you could just go through the PA. You'll probably DI for recording anyway.
maskedsuperstar.bandcamp.com
waylon
Post by waylon » Tue Jun 06, 2017 8:49 am
thedavegreen
Post by thedavegreen » Mon Nov 13, 2017 11:24 pm
Sorry I'm a bit late to this party. I like my Line 6 Studio Lowdown 110. It's small and portable, and it packs a decent punch.
You don't have to use all of the pre-programmed settings (a few of them are kinda nutso). You can usually pick up a used one for under $100 if you can find one.
Pepe Silvia
Post by Pepe Silvia » Tue Nov 14, 2017 6:26 am
I have been eyeing up an Ashdown CTM 15 for use at home
