As far as cheap practice amps go...
- chrisjedijane
Re: As far as cheap practice amps go...
I've got a little '74 SF champ and it's unbelievable (especially since I paid £50 for it). Unfortunately the speaker's died on me, but it shouldn't be too hard to get a replacement.
- dinosaur
I blew the speaker in mine as well and replaced it with a Weber. It sounds great and I highly recommend it.chrisjedijane wrote: I've got a little '74 SF champ and it's unbelievable (especially since I paid £50 for it). Unfortunately the speaker's died on me, but it shouldn't be too hard to get a replacement.
- burker
I have a old 60's ampeg jet which I found for pretty cheap, its small, but actually pretty loud, so maybe it wouldnt work. They are worth trying to find though, maybe some are on ebay?
- chrisjedijane
I think I'll check those out, actually. Was it expensive?dinosaur wrote: I blew the speaker in mine as well and replaced it with a Weber. It sounds great and I highly recommend it.
- dinosaur
He has quite a range of 4ohm 8" speakers. I bought mine about 6 years ago and the model numbers are different now. It was about 70 dollars and was one of the vintage alnico. But, I have heard Champs with his Signature series speakers, both ceramic and alnico models, and they sound absoultely fantastic. I think they are only 30 bucks or so. He may also be able to fix your old speaker, depending on what happened.chrisjedijane wrote:I think I'll check those out, actually. Was it expensive?dinosaur wrote: I blew the speaker in mine as well and replaced it with a Weber. It sounds great and I highly recommend it.
- fuzzjunkie
i run a Vox Tonelab through a mixer and KRK monitors...i used to play through a small champ, but even that could be too loud late at night and I usually play through an AC-30, so now I can get that sound and control the volume or use headphones if I have to.
sleeping on a bed of fuzz and feedback
- Vinkie
+1 on the Laney LC15R I used one for a few years and it has a nice sound indeed. I had an early one with the crappy HH speaker so I put a Jensen P10R in it which sounded thin at first but got better after a few hours of playing. Laney reacted to customer comments and the newer ones have a quite decent Celestion onboard.
The Epi Valve Jr are alot of fun too although the drive is somewhat less controllable at livingroom volume. However at a similar price I'd get this instead of the Valvetronix and try some better tubes (maybe a JJ EL84 and a 5751 for a brighter sound with more headroom). I love Champs too and there are much more vintage lower wattage amps around like late '50s GA-8 Gibsonettes, Valco/Gretsch/Supro, ... Bringing these back to life and maybe slightly mod them to suit your taste can be alot of fun.
- flatfiver
The Weber Sig 8 alnico I've got in my Champ was $40-$45 a couple months ago, can't remember exactly. I think the ceramic models are a little cheaper. It's a beautiful speaker.dinosaur wrote: He has quite a range of 4ohm 8" speakers. I bought mine about 6 years ago and the model numbers are different now. It was about 70 dollars and was one of the vintage alnico. But, I have heard Champs with his Signature series speakers, both ceramic and alnico models, and they sound absoultely fantastic. I think they are only 30 bucks or so. He may also be able to fix your old speaker, depending on what happened.
- Jez
Mine had the HH speaker too... Not nice. However, I had two to use in stereo, and also two 2x12 cabs with G12H30 Rola Celestions in. I gigged that whole setup a couple of times and it was a very nice setup.Vinkie wrote: +1 on the Laney LC15R I used one for a few years and it has a nice sound indeed. I had an early one with the crappy HH speaker so I put a Jensen P10R in it which sounded thin at first but got better after a few hours of playing. Laney reacted to customer comments and the newer ones have a quite decent Celestion onboard.
anyone can play guitar
