I spent quite a bit of time experimenting with Mic's & Mic placement in my Studio. I have discovered a few Mic's & Placements of Mic's that work well. Also the best Amp recording tecniques Mono & Stereo that work wel in my Studio.øøøøøøø wrote: ↑Fri Feb 22, 2019 9:28 pmIn most things, the options are literally infinite. The skill and art is knowing which option to select for a given moment. Focus and clarity-of-approach (whether playing an instrument, or recording one) is what I'm after.
Have I, and will I, set up multiple amps and multiple microphones at times? Yes, but only for a purpose, and only with purpose. Generally, complex setups are not called for, and do not best serve the music I find myself working on.
In other words--if I'm going to do something complicated, there will be a clear artistic reason for doing so.
I usually stick to them in each of their given situations. Great results & saves time...
Every Studio & set up is different. Take a little time & you can figure out the best methods for your studio...
